i think i found the info, if anyone can verify. i usually use the dei info but no longer have access. if any moderator could delete the garbled post above that would be great.
MODEL YEAR(S)
4-RUNNER 2010 -2011
KEY T-HARNESS IMMOBILIZER
TOYKEY- 2 N/A TOYOTA'S TRANSPONDER SYSTEM, See NOTE #1
PART COLOR LOCATION
12 VOLT CONSTANT BLACK (+) @ DASH FUSE BOX, (WHITE, 1-Pin Plug(E), Pin 1
STARTER RED (+) NOTE #2 @ IGNITION SWITCH, (WHITE, 8-Pin Plug) Pin 8
STARTER 2 BLACK (+) @ IGNITION SWITCH, (WHITE, 8-Pin Plug) Pin 1
IGNITION 1 BLACK (+) NOTE #3 @ IGNITION SWITCH, (WHITE, 8-Pin Plug) Pin 6
IGNITION 2 PURPLE (+) NOTE #4 @ IGNITION SWITCH, (WHITE, 8-Pin Plug) Pin 4
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 RED (+) NOTE #5 @ IGNITION SWITCH, (WHITE, 8-Pin Plug) Pin 3
ACCESSORY /HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) RED (-) @ BODY ECU, (WHITE, 30-Pin Plug), Pin 30, NOTE #6
PARKING LIGHTS ( + ) GREEN (+) @ DASH FUSE BOX, (WHITE, 36-Pin Plug(F), Pin 16
POWER LOCK BLACK (TYPE B), @ DASH FUSE BOX, (WHITE, 30-Pin Plug), Pin 9(TEST using Passenger Switch)
POWER UNLOCK WHITE (TYPE B),NOTE #7 @ DASH FUSE BOX, (WHITE, 30-Pin Plug), Pin 10(TEST using Passenger Switch)
DOOR TRIGGER RED (-) @ DASH FUSE BOX, (WHITE, 36-Pin Plug(F), Pin 27
DOMELIGHT SUPERVISION GREEN (-) @ DASH FUSE BOX, (REAR, WHITE, 40-Pin Plug(B), Pin 18
TRUNK RELEASE Use Trunk Release Motor wire
SLIDING POWER DOOR N/A
HORN GRAY/BLUE (-) @ DASH FUSE BOX, (WHITE, 40-Pin Plug(D), Pin 29
TACH PINK (AC) @ DATA LINK Connector, (WHITE, 16-Pin Plug), Pin 9
WAIT TO START LIGHT N/A
BRAKE PURPLE / GREEN to BLUE (+) @ BRAKE SWITCH or DASH FUSE BOX, (WHITE, 36-Pin Plug(F), Pin 29
FACTORY ALARM DISARM GRAY (-) (Requires Double Pulse) NOTE #8 @ BODY ECU, (WHITE, 30-Pin Plug), Pin 24, NOTE #6
ANTI-THEFT TOYOTA'S TRANSPONDER SYSTEM, See NOTE #1 @ IGNITION SWITCH TUMBLER
EXTRA INFORMATION
NOTE #1: TOYOTA'S TRANSPONDER SYSTEM, Requires Bypass Module: (For Remote Starting Only) Part #791 Bypass, (Requires Extra Key) for Operation. (For Remote Starting Only) Part # PK-ALL Bypass. (No Extra Key Required for Operation) 2-KEYS Required to Program Module. (For Remote Starting/Door Locks) Part # DB-ALL (No Extra Key Required for Operation) 1-KEY Required for Programming. To order please go to the SECURITY BYPASS MODULE Page or INTERFACE BYPASS MODULE Page on this website.
NOTE #2: on vehicles with SMART KEY, PUSH-BUTTON Start, the START Switch 1 wire is LT. GREEN (-) and the START Switch 2 wire is RED (-) at the ENGINE Switch (BLACK, 14-Pin Plug) Pins 7 and 2.
NOTE #3: on vehicles with SMART KEY, PUSH-BUTTON Start, the Ignition wire is a BLUE (+) located in the DRIVERS KICK PANEL, (WHITE, 48-Pin Plug) Pin 7
NOTE #4: on vehicles with SMART KEY, PUSH-BUTTON Start, the Ignition 2 wire is a PURPLE (+) located at the DASH FUSE BOX, (REAR, WHITE, 56-Pin Plug(C) Pin 52
NOTE #5: on vehicles with SMART KEY, PUSH-BUTTON Start, the ACCESSORY wire is a RED (+) located at the DASH FUSE BOX, (REAR, WHITE, 56-Pin Plug(C) Pin 48 NOTE #6: the BODY ECU is located under the DRIVERS DASH, it is attached to the RIGHT side of the DASH FUSE BOX.
NOTE #7: this wire is only needed if the Door Locks do not function with the Aftermarket System while the vehicle is running. All other times just use the Factory Alarm Disarm wire.
NOTE #8: TEST this wire while turning the Key in the Drivers Door, this wire will also Unlock the doors.
