hooking up usa 2000 and subs
anoble1
Member - Posts: 15
Posted: July 13, 2011 at 4:56 PM / IP Logged
I have a USA-2000. I need help hooking everything up. I have 2 Orion H2's 12.4. Dual 4 ohm subs. Can someone help me? Someone told me the only way I can run those subs is if I do a 4-ohm load, but idk.
Platinum - Posts: 13,670
Posted: July 13, 2011 at 9:45 PM / IP Logged
Is the amp a 1 or a 2 channel amp?  What is the minimum safe operating impedance of the amp?
anoble1
Member - Posts: 15
Posted: July 14, 2011 at 7:27 AM / IP Logged
Let me see if I can answer you correctly. It says 2000W @ 2 Ohms. Then it says 1 Ohm: 1000 Watts, someone told me the 1 Ohm meant stereo not mono.
Watts Per Channel
250W @ 4 ohms, 500W @ 2 ohms, 1000W @ 1 ohm, Fuse 300AMP
Posted: July 14, 2011 at 4:48 PM / IP Logged
1 Ohm has nothing to do with the number of channels.  Let's try it this way.  On the speaker terminals does it say left or right?
Is it a 2000.1?
anoble1
Member - Posts: 15
Posted: July 15, 2011 at 10:19 AM / IP Logged
It is a 2 channel amp. It has 2 positives and 2 negatives.
hooking up usa 2000 and subs - Last Post -- posted image.
anoble1
Member - Posts: 15
Posted: July 20, 2011 at 9:55 AM / IP Logged
Any help?
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
