2004 GMC Canyon Pickup Passlock II
mysticalp
Copper - Posts: 63
Posted: August 03, 2011 at 9:13 AM / IP Logged
Ok,
I have chnged the programming on the Autopag to the "Voltage Checking Type"  I am much farther ahead now doing it this way!!  Now would you be able to tell me how to keep the truck running?  It remote starts but doesn't stay running.  So basically, the truck turns over (not over -cranking) seems that it starts for a second then shuts off?  Any ideas as to what I can do??
Pete
Platinum - Posts: 7,783
Posted: August 03, 2011 at 1:46 PM / IP Logged
Passlock2 cuts off the fuel supply to the engine.  If it cranks and runs for a second, it sounds like you are not bypassing the Passlock2.  Did you cut the Passlock2 wire and solder the correct wires from the bypass to the cut ends?.  Did the iDatalink module program as listed in the install guide?  Are there any instrument panel lights ( Security ) on during a remote start attempt?
mysticalp
Copper - Posts: 63
Posted: August 03, 2011 at 8:25 PM / IP Logged
Kreg,
Thanks once again!  I double checked and had the iDatalink passlock wire on the wrong end of the Vehicle passlock wire.  Everything works great!!  Thank-you.
Pete
Posted: August 03, 2011 at 8:37 PM / IP Logged
Well done!!   2004 GMC Canyon Pickup Passlock II - Page 2 -- posted image.
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
