2010 VW Jetta Alarm/Remote Start Wiring
mustyk@att.net
Copper - Posts: 132
Posted: August 03, 2011 at 9:27 PM / IP Logged
Does anybody have wiring diags for remote start for 2010 VW Jetta?
thetopinstaller
tonanzith
Gold - Posts: 593
Posted: August 07, 2011 at 10:14 PM / IP Logged
12 Volts     RED / black (50A), RED / yellow (40A)     +     VESCM, 2 pin plug (L), pin 1; 11 pin plug (A), pin 1
Second 12 Volts     red (40A)     +     VESCM, 11 pin plug (D), pin 1
Starter     RED / black or RED / brown     +     VESCM, 12 pin plug (G), pin 1
Second Starter     N/A
Ignition     black     +     VESCM, 12 pin plug (G), pin 11
Second Ignition     N/A
Third Ignition     N/A
Accessory     N/A
Second Accessory     N/A
Third Accessory     N/A
Keysense     N/A
Data Bus     N/A
Can Bus High     ORANGE / green     data     VESCM, 12 pin plug (G), pin 8
Can Bus Low     ORANGE / brown     data     VESCM, 12 pin plug (G), pin 7
Can Bus Sw     N/A
Power Lock     BROWN / green     -     Driver Door Control Module, 32 pin plug, pin 32
Power Unlock     same as power lock     - 250 ohms
Lock Motor     yellow     5 wire     Driver Door Control Module, 20 pin plug, pin 13
Driver Unlock Motor     purple     5 wire     Driver Door Control Module, 20 pin plug, pin 12
Passenger Unlock Motor     purple     5 wire     Passenger Door Control Module, 20 pin plug, pin 12
Parking Lights (-)     N/A
Parking Lights (+)     gray / YELLOW     +     VESCM, 16 pin plug (E), pin 1
Hazards     BROWN / red     -     VESCM, 12 pin plug (G), pin 9
Turn Signal (Left)     BLACK/ white (F); BLACK/ white (R)     +     VESCM, 11 pin plug (D), pin 11; 12 pin plug (C), pin 11
Turn Signal (Right)     BLACK/ green (F); BLACK/ green (R)     +     VESCM, 11 pin plug (A), pin 6; 12 pin plug (B), pin 10
Headlight     WHITE/ black     +     VESCM, 16 pin plug (E), pin 8
AutoLights     purple (interrupt to turn off autolights)     +     VESCM, 16 pin plug (E), pin 14
Reverse Light     gray/white or BLACK/ blue     +     VESCM, 12 pin plug (C), pin 12
Left Front Door Trigger     BROWN / yellow     -     Driver Door Control Module, 20 pin plug, pin 7
Right Front Door Trigger     BROWN / yellow     -     Passenger Door Control Module, 20 pin plug, pin 7
Left Rear Door Trigger     white or BLACK/ gray     -     Left Rear Door Control Module, 18 pin plug, pin 7
Right Rear Door Trigger     white or BLACK/ gray     -     Right Rear Door Control Module, 18 pin plug, pin 7
Remote Start, Security, Keyless Entry, Accessories (Continued)
Item     Wire Color     Polarity     Wire Location
Dome Supervision     RED / purple     -     VESCM, 12 pin plug (B), pin 11
Trunk/Hatch Pin     BROWN / black     -     driver kick or Comfort System Control Module, 18 pin plg, pin 15
Rear Glass Pin     N/A
Hood Pin     BROWN / green     -     VESCM, 8 pin plug (F), pin 5
Trunk/Hatch Release     blue     -     Driver Door Control Module, 32 pin plug, pin 30
Trunk Release Motor     RED / blue or purple     5 wire     driver kick or Comfort System Control Module, 18 pin plug, pin 4
Fuel Door Release     purple (sedan), use fuel door motor (wagon)     -     Driver Door Control Module, 32 pin plug, pin 13
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     GREEN / WHITE     -     Driver Door Control Module, 20 pin plug, pin 16
Factory Alarm Disarm     same as factory alarm arm     - 250 ohms
Disarm No Unlock     Transponder and ignition
Trunk Alarm Shunt     N/A
Tachometer     BROWN / stripe (4-cyl), NOT RED / black (5-cyl)     ac     any fuel injector
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     PURPLE / black     -     VESCM, 16 pin plug (E), pin 7
Fuel Pump     RED / black     -     VESCM, 11 pin plug (A), pin 10
Rear Defroster     black or white     + latched     VESCM, 10 pin plug (K), pin 1
Mirror Defroster     yellow     -     Driver Door Control Module, 32 pin plug, pin 28
Left Front Heated Seat     purple     5 wire     Heated Seats Control Module, 8 pin plug, pin 5
Right Front Heated Seat     PURPLE / blue     5 wire     Heated Seats Control Module, 8 pin plug, pin 1
Speed Sense     WHITE/ purple     ac     instrument cluster, 36 pin plug, pin 28
Brake Wire     BLACK/ red (functions with ignition on only)     +     VESCM, 16 pin plug (E), pin 2
Parking Brake     BROWN / yellow     -     parking brake switch, 2 pin plug, pin 1
Horn Trigger     BLACK/ white     +     VESCM, 6 pin plug (J), pin 6
Wipers     (data bus)
Left Front Window (Up/Down)     use factory alarm arm/disarm
Right Front Window (Up/Down)     see left front window
Left Rear Window (Up/Down)     see left front window
Right Rear Window (Up/Down)     see left front window
Sun Roof (Open/Close)     use factory alarm arm/disarm
Sun Roof (Limit/Close)     N/A
Memory Seat 1     blue / YELLOW     + resistor     Memory Seat Control Module, 26 pin plug, pin 13
Memory Seat 2     same as memory seat 1     + resistor
Memory Seat 3     blue/green     + resistor     Memory Seat Control Module, 26 pin plug, pin 8
Gary Sather
mustyk@att.net
Copper - Posts: 132
Posted: August 08, 2011 at 3:46 PM / IP Logged
Have you tested this wiring ?  Does it work? And did you have any problems?
thetopinstaller
mustyk@att.net
Copper - Posts: 132
Posted: August 08, 2011 at 3:51 PM / IP Logged
This is for 2009 Jetta. 2010 is different. The VESCM does not have these plugs and colors!
thetopinstaller
tonanzith
Gold - Posts: 593
Posted: August 08, 2011 at 4:08 PM / IP Logged
Sorry here is 2010 and yes this is all tested.
WIRE          COLOR          POLARITY          LOCATION
Battery          VIOLET          (+)          IGNITION SWITCH HARNESS
LOW CURRENT, FOR HIGH CURRENT APPLICATION USE RED AT UNDER DASH FUSEBOX
Ignition 1          YELLOW          (+)          IGNITION SWITCH HARNESS
TO ACCESS THE IGNITION SWITCH HARNESS YOU MUST REMOVE THE STEERING COLUMN COVER AND CATCH THE WIRES BEFORE THE STEERING COLUMN CONTROL MODULE
Starter 1          RED          (+)          IGNITION SWITCH HARNESS
All Door Trigger          RED / YELLOW          (-)          AT FOOTWELL LIGHT UNDER DASH
TO AVOID DOMELIGHT DELAY USE INDIVIDUAL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE
Domelight Super          RED / VIOLET          (-)          VEHICLE ELECTRIC SYSTEM CONTROL MODULE
LF Latch          BROWN / YELLOW          (-)          DRIVER DOOR MODULE IN DRIVER DOOR
RF Latch          BROWN / YELLOW          (-)          PASSENGER DOOR MODULE IN FRONT PASSENGER DOOR
LR Latch          WHITE          (-)          REAR LEFT DOOR MODULE IN REAR LEFT DOOR
THERE ARE MULTIPLE WHITE WIRES IN THIS CONNECTOR, BE SURE TO TEST FOR DOOR TRIGGER
RR Latch          WHITE          (-)          REAR RIGHT DOOR MODULE IN DOOR
Trunk Trigger          BROWN / BLACK          (-)          VEHICLE ELECTRIC SYSTEM CONTROL MODULE
ALSO AT TRUNK LIGHT
Hood Trigger          BROWN / GREEN          (-)          AT VEHICLE HOOD PIN SWITCH
ALSO AT VEHICLE ELECTRIC SYSTEM CONTROL MODULE
Alarm Disarm
WITH FACTORY REMOTE OR IGNITION AND VALID TRANSPONDER SIGNAL
Alarm Arm          GREEN / WHITE          (-)          AT MODULE IN DRIVERS DOOR
Parking Lights          WHITE/ BLACK & RED / WHITE          (CLOSED)          AT VEHICLE LIGHT SWITCH
A CLOSED CIRCUIT BETWEEN THE WHITE/ BLACK AND RED / WHITE WIRES WILL ACTIVATE THE PARKING LIGHTS, MUST CUT AND ISOLATE THE RED / WHITE WIRE FROM THE SWITCH WITH A RELAY
Convenience
All Hazrd Lights          BROWN / RED          (-)          VEHICLE ELECTRIC SYSTEM CONTROL MODULE
ALSO AT HAZARD SWITCH
Parking Brake          BROWN / YELLOW          (-)          AT VEHICLE PARKING BRAKE
ALSO IN HARNESS TO GAUGES
Trnk Release          BLUE          (-)          AT TRUNK RELEASE SWITCH IN DRIVER DOOR
ALSO RED / BLUE (+) AT VEHICLE ELECTRIC SYSTEM CONTROL MODULE
Fuel Dr Release          VIOLET          (-)          AT GAS DOOR RELEASE SWITCH IN DOOR
Remote Start
Accessory 1          GREEN          (+)          IGNITION SWITCH HARNESS
Anti-Theft Type          VOLKSWAGEN TRANSPONDER III® VEHICLE IMMOBILIZER
Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense          BLUE          (+)          IGNITION SWITCH HARNESS
Tachometer          RED / WHITE          (-)          AT INJECTOR #1
ALSO AT ECM MODULE AT CENTER OF FIREWALL
Speed Sense          BROWN          (AC)          AT ABS CONTROL MODULE UNDER HOOD NEAR PASSENGER SIDE FIREWALL
Brake Lights          BLACK/ RED          (+)          AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights          BLACK/ BLUE          (+)          VEHICLE ELECTRIC SYSTEM CONTROL MODULE
Horn          BROWN          (-)          VEHICLE ELECTRIC SYSTEM CONTROL MODULE
Rear Defrost          BLACK/ GREEN
Gary Sather
bcbsox
Posted: January 09, 2014 at 7:03 PM / IP Logged
I'm missing how to get at the ignition wires. Anybody have a second to shed some light on it?
Thanks!
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
