'03 Honda CRV Wiring
sound decision
Member - Posts: 39
Posted: April 27, 2003 at 7:47 PM / IP Logged
looking for the wiring for a 03 hondra crv. putting in a remote starter with alarm and keyless.
thanks in advance
Moderator - Posts: 12,488
Posted: April 27, 2003 at 9:32 PM / IP Logged
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|        ACCESSORY|BLACK/ red           |+  |ignition harness            |
| SECOND ACCESSORY|WHITE/ red           |+  |ignition harness            |
|       POWER LOCK|WHITE/ blue          |-  |gray plug above drivers kick|
|     POWER UNLOCK|WHITE/ green         |-  |gray plug above drivers kick|
|       LOCK MOTOR|yellow/black        |   |driver kick panel           |
|     UNLOCK MOTOR|YELLOW /GREEN        |   |driver kick panel           |
|    DISARM DEFEAT|yellow              |   |passenger kick panel        |
| PARKING LIGHTS +|RED / black           |   |driver kick panel           |
| PARKING LIGHTS -|blue                |   |factory alarm plug *1       |
|       HEADLIGHTS|blue/red            |-  |factory alarm plug *1       |
|     DOOR TRIGGER|*2                  |-  |factory alarm plug *1       |
| DOME SUPERVISION|comes on with unlock|   |                            |
|  TRUNK/HATCH PIN|grn/wht & red *5    |-  |factory alarm plug *1       |
|         HOOD PIN|yellow/red          |-  |factory alarm plug *1       |
|TRNK/HTCH RELEASE|BLACK / YELLOW        |-  |driver kick panel           |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|blue                |   |test connector *3           |
|      SPEED SENSE|blue/white          |   |cruise control module *4    |
|       BRAKE WIRE|WHITE/ black         |+  |brake pedal switch          |
|     HORN TRIGGER|orange              |-  |steering column             |
|           WIPERS|blue (L), blu/yel(H)|-  |steering column             |
|  LF WINDOW UP/DN|RED / blk - RED / yel   |A  |driver window switch        |
|  RF WINDOW UP/DN|blu/red - blu/wht   |A  |driver kick panel           |
|  LR WINDOW UP/DN|blu/blk - brown     |A  |driver kick panel           |
|  RR WINDOW UP/DN|blu/org - blu/yel   |A  |driver kick panel           |
| SUN RF OPN/CLOSE|grn/yel - grn/blk   |A  |relays above driver kick    |
|        RADIO 12V|WHITE/ red           |+  |radio                       |
|     RADIO GROUND|black               |+  |radio                       |
|     RADIO SWITCH|yellow/red          |+  |radio                       |
| RADIO ILLUMINATE|RED / black           |+  |radio                       |
|       LF SPEAKER|grn/blk - lt green  |   |radio                       |
|       RF SPEAKER|grn/yel - gry/red   |   |radio                       |
|       LR SPEAKER|blu/wht - blu/blk   |   |radio                       |
|       RR SPEAKER|pink - blu/yel      |   |radio                       |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start.  Use the universal bypass module  *1 The factory alarm plug is a green plug to the left of the steering column.  *2 The drivers door trigger is green, and lt GREEN/ red catches all the other doors. Use both and diode isolate each.  *3 The test connector is next to the battery.  *4 The cruise control module is to the left of the steering column.  *5 The GREEN / WHITE is for the hatch glass pin switch, and the red is for the tailgate pin switch.
NowYaKnow
Gold - Posts: 1,217
Posted: May 01, 2003 at 5:09 AM / IP Logged
Just a little update.. For the hatch release on these I would NOT use the BLACK / YELLOW in the driver kick. Use the BLACK / YELLOW (+) in the green factory alarm plug. The one in the driver kick gave me a bunch of problems and was killing my modules for some reason. I hooked it up and it would work fine for a couple tries and then went dead, along with the trunk switch in the door itself. That wire also would pop the glass when poked with A METER. So like I said I would definately go with the BLACK / YELLOW (+) in the factory alarm plug.
Saturday, May 18, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
