left front fader for radio out
stgeorge2011
Posted: September 25, 2011 at 11:23 PM / IP Logged
Hi, People
I have a 2001 Jeep Cherokee with a left-front (driver side) fader out on a Chrysler(Mitsubishi) radio model P04704383AH. I'm trying to find a schematic so I can at least take stab a at troubleshooting and/or repairing an output or channel transistor on the module. Any other suggestions outside of locating the schematic or repair manual would be helpful also.
Thanks. Rob
Platinum - Posts: 13,667
Posted: September 26, 2011 at 10:23 AM / IP Logged
Newer radios do not have discrete circuitry on the amplifier sections. There is a single or maybe 2 output ICs. Are you sure you do not have a bad speaker?
ac0j
Copper - Posts: 121
Posted: October 07, 2011 at 11:50 PM / IP Logged
Also if the speaker is in the door, check the wires inside the rubber boot between the car and the door.  Often you will find wires cracked, shorted, broken or all of those! inside the boot!
Posted: October 08, 2011 at 1:40 PM / IP Logged
I have never seen a failure of OEM wiring that did not have some form of outside help.
