2011 Honda Fit Alarm/Remote Start Wiring
audiophyle_247
Copper - Posts: 79
Posted: October 14, 2011 at 9:08 PM / IP Logged
Putting a 5901 into my 2011 Honda Fit and could really use a little wiring info if anyone has it.
Greatly appreciate it.
Unless it raises the hair on the back of your neck, its only noise!
chev104275
Gold - Posts: 1,428
Posted: October 15, 2011 at 8:03 AM / IP Logged
         #82748: 2011 HONDA FIT 4DR HATCHBACK WITH 1.5L ENGINE AND 4-SPEAKER AUDIO SYSTEM
Security
     WIRE          COLOR          POLARITY          LOCATION
Battery          WHITE          (+)          IGNITION SWITCH HARNESS
THIS WIRE IS FUSED AT 50 AMPS
Ignition 1          YELLOW          (+)          IGNITION SWITCH HARNESS
Starter 1          PINK          (+)          IGNITION SWITCH HARNESS
Domelight Super          BLUE          (-)          UNDER DASH FUSEBOX
LF Latch          BLUE          (-)          UNDER DASH FUSEBOX
RF Latch          LIGHT GREEN          (-)          UNDER DASH FUSEBOX
LR Latch          PINK          (-)          UNDER DASH FUSEBOX
RR Latch          GREEN          (-)          UNDER DASH FUSEBOX
Trunk Trigger          ORANGE          (-)          UNDER DASH FUSEBOX
RED AT TRUNK SWITCH
Hood Trigger          VIOLET          (-)          UNDER DASH FUSEBOX
ONLY ON VEHICLES WITH FACTORY ALARM
Alarm Disarm          GREEN          (-)          UNDER DASH FUSEBOX
TEST THIS WIRE WHILE TURNING THE KEY IN THE DRIVER DOOR LOCK CYLINDER
Alarm Arm          VIOLET          (-)          UNDER DASH FUSEBOX
Parking Lights          GRAY          (+)          UNDER DASH FUSEBOX
Low Crr Pk Lights          GRAY          (-)          LIGHT SWITCH HARNESS
ALSO AT UNDER DASH FUSEBOX PIN M7
Convenience
Headlights-Lo          RED          (-)          VEHICLE LIGHT SWITCH
ALSO AT UNDER DASH FUSEBOX PIN M5
All Hazrd Lights          PINK          (+)          UNDER DASH FUSEBOX
ALSO AT VEHICLE HAZARD SWITCH
Wipers-Lo          ORANGE          (-)          WIPER CONTROL SWITCH
ALSO AT UNDER DASH FUSEBOX PIN #M11
Wipers-Hi          RED          (-)          WIPER CONTROL SWITCH
ALSO AT UNDER DASH FUSEBOX PIN M10
Parking Brake          ORANGE          (-)          PARKING BRAKE SWITCH
ALSO IN HARNESS TO GAUGES
Remote Start
Accessory 1          ORANGE          (+)          IGNITION SWITCH HARNESS
Accessory 2          RED          (+)          IGNITION SWITCH HARNESS
Anti-Theft Type          UNIVERSAL IMMOBILIZER
Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense          GRAY          (-)          UNDER DASH FUSEBOX
ALSO IN IGNITION SWITCH HARNESS
Neutral Safety          ORANGE          (-)          UNDER DASH FUSEBOX
ON AUTOMATIC VEHICLES THIS WIRE WILL TEST (-) WHEN THE CAR IS IN PARK OR NEUTRAL, ON MANUAL VEHICLES THIS WIRE WILL TEST (-) WHEN THE CLUTCH PEDAL IS DEPRESSED
Tachometer          LIGHT BLUE          (AC)          AT PCM MODULE UNDER HOOD
Crankshaft Sensor          BLUE          (AC)          IN HARNESS AT PCM MODULE BETWEEN BATTERY AND FIREWALL
DO NOT DISCONNECT PCM MODULE - OBTAIN WIRE CONNECTION IN BUNDLED HARNESS GOING TO PCM OR GET THE WIRE AT THE SENSOR ON BOTTOM OF ENGINE NEAR ENGINE MOUNT UNDER A BLACK PLASTIC COVER.
Camshaft Sensor          GREEN          (AC)          IN HARNESS AT PCM MODULE BETWEEN BATTERY AND FIREWALL
DO NOT DISCONNECT PCM MODULE - OBTAIN WIRE CONNECTION IN BUNDLED HARNESS GOING TO PCM OR GET THE WIRE AT THE SENSOR ON TOP OF ENGINE NEAR THROTTLE BODY.
Speed Sense          BLUE          (AC)          RADIO HARNESS
ALSO AT PCM PIN A30
Low Crr. Pk Lights          GRAY          (-)          LIGHT SWITCH HARNESS
Brake Lights          LIGHT GREEN          (+)          AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights          GREEN          (+)          UNDER DASH FUSEBOX
Horn          ORANGE          (-)          IN HARNESS TO STEERING COLUMN
Rear Defrost          VIOLET
ALSO AT UNDER DASH FUSEBOX PIN K2, THIS WIRE WILL CONTROL HEATED MIRRORS IF EQUIPPED
Modules
     WIRE          LOCATION
Module 1          PCM - POWERTRAIN CONTROL MODULE - UNDER HOOD NEAR DRIVER SIDE FIREWALL
Module 2          ABS CONTROL MODULE - UNDER HOOD ON PASSENGER SIDE
Module 3          MICU - UNDER DRIVER SIDE OF DASH ATTACHED TO FUSE BOX
Doorlocks/Windows
Power Unlock          GRAY          (-)          UNDER DASH FUSEBOX
A DOUBLE PULSE ON THE FACTORY ALARM DISARM WIRE WILL ALSO UNLOCK ALL DOORS
PowerLock          LIGHT BLUE          (-)          UNDER DASH FUSEBOX
A PULSE ON THE FACTORY ALARM ARM WIRE WILL ALSO LOCK THE DOORS
Driver Mtr Unlock          LIGHT GREEN          (REV)          UNDER DASH FUSEBOX
Driver Mtr Lock          PINK          (REV)          UNDER DASH FUSEBOX
Pas Mtr Unlock          YELLOW          (REV)          UNDER DASH FUSEBOX
Pas Mtr Lock          LIGHT BLUE          (REV)          UNDER DASH FUSEBOX
LF Window Up          ORANGE          (REV)          MAIN POWER WINDOW SWITCH
LF Window Dn          BLUE          (REV)          MAIN POWER WINDOW SWITCH
RF Window Up          WHITE          (REV)          MAIN POWER WINDOW SWITCH
RF Window Dn          YELLOW          (REV)          MAIN POWER WINDOW SWITCH
LR Window Up          VIOLET          (REV)          MAIN POWER WINDOW SWITCH
LR Window Dn          GREEN          (REV)          MAIN POWER WINDOW SWITCH
RR Window Up          LIGHT GREEN          (REV)          MAIN POWER WINDOW SWITCH
RR Window Dn          RED          (REV)          MAIN POWER WINDOW SWITCH
      Note: Code Systems makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Code Systems disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
