viper remote start 5101 problems
mattintc
Posted: October 22, 2011 at 12:56 AM / IP Logged
I have a viper 5101 and it has one big issue. The lock and unlock side of it works flawlessly along with its other features in the security area. the problem im having is the fact it wont function for jack in keeping the car running in pit stop mode or wont even start the car up at all if i press the remote start button on the remote. All it does is click a bunch of times flashing the parking lights nothing else no click from inside or nothing. any help would be beyond appreciated at this point. i also have the newer 5101 with the 18 pin harness on it. i also have put it into automatic mode for my car. i have tried the shutdown diagnostic procedure too and it dose no blinking or nothing.
Platinum - Posts: 7,783
Posted: October 22, 2011 at 8:21 AM / IP Logged
Might help if you posted the vehicle  year, make & model.  Sounds like an ignition wiring problem, so listing your H3 connections is a good idea also.
Try to count the blinks when you initiate a remote start.  Eight blinks is Neutral Safety issue and seven blinks means you are still in Manual Trans Mode.
mattintc
Posted: October 22, 2011 at 12:30 PM / IP Logged
wth?! i thought i figured out my neutral saftey switch problem!!
mattintc
Posted: October 22, 2011 at 12:32 PM / IP Logged
ALSO i followed a different wiring diagram to see if that corrected my problem because the other remote starter functioned perfectly on the wires i had put it on.
