2001 chrysler town & country aftermarket hu
pongaselo
Posted: November 26, 2011 at 7:09 PM / IP Logged
My client asked me to replace an aftermarket AM/FM Cd in their T&C which I did, despite the fact that the battery was dead (their request). After completing the service on this rental unit, they called me to remove the factory radio hung under the dash. This I also did. When the new battery was installed the radio lit up but no one was home. Since then, I have done the work and found out that the radio was needed to turn on the infinity amps. They 86ed the old radio and I have not been able to come up with an AMp turn on work around. Anyone had any success there.
jseibold
Copper - Posts: 98
Posted: November 30, 2011 at 1:54 PM / IP Logged
Look for a Gray/green wire in the vehicle plugs (it's usually in the black plug at the end).  This is the factory amp turn on wire.  If the head unit you are working with does not put out 12 volts to this wire when the head unit is on, you can disconnect it from the head unit and hook the Gray/green wire to 12v switched power and it should work.
buddholly
Copper - Posts: 244
Posted: November 30, 2011 at 6:53 PM / IP Logged
Grey/Green behind the radio is actually the factory amp ground.  There is a GREEN/ grey wire in the driver and passenger kick panels that are actually the factory amp turn on leads.  You need to use a relay.
85 - remote wire from aftermarket radio
86 - Grey/Green behind radio
87 - 12v
30 - GREEN/ Grey in either kick panel
jseibold
Copper - Posts: 98
Posted: December 01, 2011 at 11:03 AM / IP Logged
Thanks for the correction buddyholly and sorry if I supplied incorrect information pongesalo.
buddholly
Copper - Posts: 244
Posted: December 02, 2011 at 3:57 PM / IP Logged
It's all good. Just did one the other day.
garfieldspence
Posted: November 14, 2012 at 2:04 PM / IP Logged
Does this require only one GREEN/ grey from either kick panel or should I connect both wires from each kick panel to the relay?
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
