relay for trunk release
eanderson651
Member - Posts: 41
Posted: November 30, 2011 at 11:05 AM / IP Logged
Hello all,
I know there are several wiring diagrams on this site for this, but I'm having a hard time determining what one is right.  I've google searched as well, and it seems every diagram says something different.
99 Nissan Maxima, trunk release requires a negative signal to pop.
The relay should be wired as follows?
Negative trigger from remote start unit to 86
Ground 87
Constant 12v to 85
Trunk release wire to 30
Is that right?
Thanks in advance!
chev104275
Gold - Posts: 1,428
Posted: November 30, 2011 at 11:36 AM / IP Logged
That is correct for that application
blanx218
Silver - Posts: 654
Posted: November 30, 2011 at 8:45 PM / IP Logged
MOst alarm and remote starts put out enough to pop a trunk on most vehicles with (-) trunk releases. I couldnt tell you the last time I used a relay on a (-) trunk release.
chev104275
Gold - Posts: 1,428
Posted: December 01, 2011 at 5:14 AM / IP Logged
I have not done a 99 maxima in a while but from what i remember that truck release wire is the trunk motor wire which is high current thats the reason for the relay
Mike M2
Platinum - Posts: 2,652
Posted: December 01, 2011 at 6:15 AM / IP Logged
I think i remember that being the case also, the output from the alarm was not enough to trigger it on this car so a relay was needed...
Mike M2
Tech Manager
CS Dealer Services
tedmond
Gold - Posts: 4,610
Posted: December 01, 2011 at 7:30 AM / IP Logged
use a relay for sure, in the tech sheet i had it didnt note to use one, and ended up burning out the trunk release on the brain (compustar 6200)
Ted
Compustar Expert
afridihamid
Member - Posts: 29
Posted: December 01, 2011 at 1:31 PM / IP Logged
If you have a 5-pin relay, you can also do it like this:
https://www.the12volt.com/installbay/forum_posts.asp~TID~129238~PN~1#641693
Either way, use a diode to protect your alarm unit.
afridihamid
Member - Posts: 29
Posted: December 01, 2011 at 1:33 PM / IP Logged
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
