2005 honda pilot viper responder one
xbimmer
Member - Posts: 26
Posted: December 03, 2011 at 12:52 AM / IP Logged
Hi ill be installing Viper responder one on 05 pilot with Tbxkey
I have a question with disarm and rearm factory alarm .
Do i need to use relay as sown on installation manual of responder one ? Or is it only for delayed pulse???
thanks a lot !
H1/1 LIGHT GREEN/
BLACK
FACTORY ALARM DISARM
This wire sends a negative pulse every time the remote start is activated
or the doors are unlocked. This can be used to pulse the disarm wire
of the vehicle’s factory anti-theft device. Use a relay to send a (-) or (+)
pulse to the disarm wire as shown in the following diagram
H1/2 GREEN / WHITE FACTORY REARM
This wire sends a negative pulse every time the remote start shuts down
or the doors are locked. This can be used to pulse the arm wire of the
vehicle’s factory anti-theft device. Use a relay to send a (-) or (+) pulse
to the arm wire.
2005 honda pilot viper responder one -- posted image.
xbimmer
Member - Posts: 26
Posted: December 03, 2011 at 1:11 AM / IP Logged
and should i go with PKALL instead of tbxkey ?
Platinum - Posts: 7,783
Posted: December 03, 2011 at 4:43 AM / IP Logged
Unless you don't mind losing a working key under the dash, go with the PKALL ( or even a PHK34 or PKH3, slightly less expensive ).
tedmond
Gold - Posts: 4,610
Posted: December 03, 2011 at 6:13 AM / IP Logged
no relay needed, a fortin honda sl3 will also take care of bypass without loosing a key
Ted
Compustar Expert
xbimmer
Member - Posts: 26
Posted: December 28, 2011 at 7:27 PM / IP Logged
all done , works perfect for couple of weeks ! used pkall found for 18 $ :) thxz
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
