Audiovox lists:
#522034: 2012 FORD ESCAPE 4DR SUV WITH 2.5L ENGINE AND PREMIUM AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery WHITE/ RED (+) RADIO HARNESS
Ground BLACK/ GRAY (-) RADIO HARNESS
Amp Turn On VIOLET/RED (+) RADIO HARNESS
LF Speaker (+) WHITE
LF Speaker (-) WHITE/ BROWN
RF Speaker (+) WHITE/ VIOLET
RF Speaker (-) WHITE/ ORANGE
LR Speaker (+) WHITE/ GREEN
LR Speaker (-) BROWN / YELLOW
RR Speaker (+) BROWN / WHITE
RR Speaker (-) BROWN / BLUE
Steering Cntrls YES
Speed Cntrl NO
Radio Security YES
Security
Battery BLUE/RED (+) IGNITION SWITCH HARNESS
Ignition 1 WHITE/ ORANGE (+) IGNITION SWITCH HARNESS
Starter 1 BLUE/WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger GRAY/VIOLET (-) IN HARNESS IN DRIVER KICKPANEL
THE INDIVIDUAL DOOR PINS REST AT (-) AND GO TO AN OPEN CIRCUIT WHEN THE DOOR IS OPENED
Domelight Super BROWN (-) AT VEHICLE LIGHT SWITCH
LF Latch GREEN/ VIOLET (OPEN) SMART JUNCTION BOX
RF Latch WHITE (OPEN) SMART JUNCTION BOX
LR Latch GREEN (OPEN) SMART JUNCTION BOX
RR Latch YELLOW (OPEN) SMART JUNCTION BOX
Trunk Trigger GRAY/ORANGE (OPEN) SMART JUNCTION BOX
Parking Lights VIOLET/WHITE (+) IN HARNESS IN DRIVERS KICKPANEL
Low Crr Pk Lights BLUE/GRAY (-) VEHICLE LIGHT SWITCH
Convenience
Headlights-Lo YELLOW/BLUE (-) VEHICLE LIGHT SWITCH
Headlights-Hi GRAY/BROWN (-) SMART JUNCTION BOX
ALSO IN HARNESS FROM STEERING COLUMN
LF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT LEFT PARKING LIGHT
RF Pk Lt Bulb VIOLET/WHITE (+) AT FRONT RIGHT PARKING LIGHT
LR Pk Lt Bulb VIOLET/WHITE (+) AT REAR LEFT PARKING LIGHT
RR Pk Lt Bulb VIOLET/WHITE (+) AT REAR RIGHT PARKING LIGHT
All Hazrd Lights BROWN / YELLOW (-) AT VEHICLE HAZARD SWITCH
LF Hazrd Bulb BLUE/GREEN (+) AT FRONT LEFT TURN LAMP
RF Hazrd Bulb YELLOW/VIOLET (+) AT FRONT RIGHT TURN LAMP
LR Hazrd Bulb GRAY/BROWN (+) AT REAR LEFT TURN LAMP
RR Hazrd Bulb VIOLET/ORANGE (+) AT REAR RIGHT TURN LAMP
Parking Brake GRAY/BLUE (-) SMART JUNCTION BOX
Trnk Release BROWN / BLUE (+) SMART JUNCTION BOX
THIS WIRE IS THE GLASS RELEASE
Remote Start
Accessory 1 VIOLET/GREEN (+) IGNITION SWITCH HARNESS
Anti-Theft Type FORD PATSŪ OR SECURILOCKŪ VEHICLE IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE/GRAY (+) IGNITION SWITCH HARNESS
Tachometer GREEN/ BLUE (AC) AT PCM MODULE
Speed Sense VIOLET/ORANGE (AC) AT PCM MODULE UNDER HOOD ON FIREWALL
Low Crr. Pk Lights BLUE/GRAY (-) VEHICLE LIGHT SWITCH
Brake Lights VIOLET/WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights GREEN/ BLUE (+) IN HARNESS IN DRIVER KICKPANEL
Horn BROWN (-) IN HRNESS AT STEERING COLUMN
ALSO AT SMART JUNCTION BOX IN DRIVER KICKPANEL
Rear Defrost WHITE/ ORANGE
Modules
WIRE LOCATION
Module 1 SMART JUNCTION BOX - PASSENGER SIDE OF CENTER CONSOLE
Module 2 PCM - UNDER HOOD AT CENTER OF FIREWALL
Doorlocks/Windows
Power Unlock YELLOW/VIOLET (-) IN HARNESS IN DRIVER KICKPANEL
PowerLock BLUE/GREEN (-) IN HARNESS IN DRIVER KICKPANEL
Driver Mtr Unlock GRAY/BROWN (REV) DRIVER DOOR LOCK MOTOR
Driver Mtr Lock BLUE/GREEN (REV) DRIVER DOOR LOCK MOTOR
LF Window Up BLUE/GRAY (REV) MASTER WINDOW SWITCH
LF Window Dn YELLOW/VIOLET (REV) MASTER WINDOW SWITCH
RF Window Up BROWN / YELLOW (REV) MASTER WINDOW SWITCH
RF Window Dn GREEN/ ORANGE (REV) MASTER WINDOW SWITCH
LR Window Up BLUE/ORANGE (REV) MASTER WINDOW SWITCH
LR Window Dn YELLOW (REV) MASTER WINDOW SWITCH
RR Window Up GRAY/VIOLET (REV) MASTER WINDOW SWITCH
RR Window Dn BROWN / GREEN (REV) MASTER WINDOW SWITCH
Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
