08 volkswagon jetta
pitoaudiovisual
Copper - Posts: 388
Posted: January 04, 2012 at 5:04 PM / IP Logged
I installed a remote starter in an 08 Jetta and i used an avital 4103 and a DBALL as well as a 556U.  The only issue i have is that the customer said that  when they remote start the vehicle and open the door the car shuts off. The car starts fine and everything but just that issue. Any one have that issue and the if so how can i fix it. The car is automatic just in case. Thanks in advance.
Confidence is the key to any project!!
enice
Silver - Posts: 857
Posted: January 04, 2012 at 6:55 PM / IP Logged
Did you connect the door trigger off the jetta to the 4103? The dball mainly gives you convenience features. Did you change the setting on the last page to disabled????
-Takeover
DISABLE (shutdown when door is open)
ENABLE ***
2.In 60 seconds open the door and press the brake.
you have to disable it.... look at last page of paperwork. page 21
pitoaudiovisual
Copper - Posts: 388
Posted: January 06, 2012 at 1:58 PM / IP Logged
Enice you are right. i didnt even notice that. The customer coming tomorrow so i will do it. Thanks i appreciate it.
enice
Silver - Posts: 857
Posted: January 06, 2012 at 2:38 PM / IP Logged
im sorry it may have been programmed to disabled...need to enable it?? or is it the other way?? wording confusing now....
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
