2003 saab 9 5
heinstal
Member - Posts: 34
Posted: January 06, 2012 at 10:43 AM / IP Logged
Hey guys anyone got the wiring for this vehicle?
Thanks in advance
~~~wael~~~
Platinum - Posts: 13,673
Posted: January 08, 2012 at 5:42 AM / IP Logged
For the entire vehicle?
heinstal
Member - Posts: 34
Posted: January 08, 2012 at 8:05 AM / IP Logged
The wiring for remote start and keyless entry please
~~~wael~~~
Posted: January 08, 2012 at 8:17 AM / IP Logged
Remote Start Info
2003 saab 9 5 -- posted image. Battery RED (+) IGNITION SWITCH HARNESS
2003 saab 9 5 -- posted image. Ignition 1 RED / BLUE (+) IGNITION SWITCH HARNESS
2003 saab 9 5 -- posted image. Ignition 2 GREEN (+) IGNITION SWITCH HARNESS
2003 saab 9 5 -- posted image. Ignition 3 ORANGE (+) IGNITION SWITCH HARNESS 2003 saab 9 5 -- posted image.
2003 saab 9 5 -- posted image. Accessory 1 VIOLET (+) IGNITION SWITCH HARNESS
2003 saab 9 5 -- posted image. Starter 1 YELLOW (+) IGNITION SWITCH HARNESS
2003 saab 9 5 -- posted image. Anti-Theft Type TRANSPONDER 2003 saab 9 5 -- posted image.
2003 saab 9 5 -- posted image. Anti-Theft Descript AN RF SIGNAL ACTIVATED SYSTEM
2003 saab 9 5 -- posted image. Key Sense ORANGE (+) IGNITION SWITCH HARNESS
2003 saab 9 5 -- posted image. Neutral Safety WHITE (-) IGNITION SWITCH HARNESS
2003 saab 9 5 -- posted image. Tachometer BLUE/RED (AC) IN HARNESS ON PASSENGER SIDE OF ENGINE
2003 saab 9 5 -- posted image. Speed Sense RED (AC) IN HARNESS NEAR BRAKE BOOSTER
2003 saab 9 5 -- posted image. Parking Lights RED / GREEN (+) AT VEHICLE LIGHT SWITCH 2003 saab 9 5 -- posted image.
2003 saab 9 5 -- posted image. Brake Lights GREEN/ GRAY (+) AT SWITCH ABOVE BRAKE PEDAL
2003 saab 9 5 -- posted image. Reverse Lights GREEN / WHITE (+) IN HARNESS IN DRIVERS KICKPANEL
Posted: January 08, 2012 at 8:22 AM / IP Logged
Notes on Remote Start info read:
Ignition 3 wire reads:
THIS WIRE IS THE SAME WIRE AS THE KEY SENSE WIRE. THIS WIRE NEEDS TO BE POWERED DOWN LAST AFTER A REMOTE START CYCLE. TO DO THIS YOU WILL NEED TO USE A RELAY AND THE THIRD IGNITION WIRE FROM THE REMOTE START TO TRIGGER THE RELAY
Anti Theft note
REQUIRES A RELAY AND COIL OF WIRE WRAPPED AROUND THE KEY AND THE KEY CYLINDER TRIM. USE THIN GAUGE INSULATED WIRE AND 8-10 WRAPS ON THE KEY AND AROUND THE KEY CYLINDER TRIM. THE TRIM RING HAS TO BE IN PLACE TO REMOTE START THE CAR.
Parking Lights
MUST USE A RELAY TO ISOLATE THE PARKING LIGHTS FROM THE SWITCH
Posted: January 08, 2012 at 8:23 AM / IP Logged
2003 saab 9 5 -- posted image. Power Unlock BLUE / YELLOW (-) AT SWITCH NEAR SHIFTER
2003 saab 9 5 -- posted image. PowerLock BLACK/ WHITE (-) AT SWITCH NEAR SHIFTER
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
