09 altima, avital 4103, dball
pitoaudiovisual
Copper - Posts: 388
Posted: February 06, 2012 at 8:44 AM / IP Logged
I did an 09 Nissan Altima R/S using a Avital 4103 and a DBALL and the car remote starters good and all the features work but 2 things are happening the check engine light is on and everytime the customer turns the car on and puts the car into drive the key symbol turns on, on the dash. Any info is greatly appreciated. I reset the check engine and it came back on after a few hours.
Confidence is the key to any project!!
offroadzj
Gold - Posts: 2,043
Posted: February 06, 2012 at 9:15 AM / IP Logged
Did you verify both ignitions are being poweRED / activated(one +, one -) and both accessory wires are getting +12v?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
pitoaudiovisual
Copper - Posts: 388
Posted: February 06, 2012 at 11:43 AM / IP Logged
yes i did.
extreme1
Silver - Posts: 1,070
Posted: February 06, 2012 at 1:04 PM / IP Logged
It's the wire you have your underhood relay attached to, recheck according the diagram and not the wire color.
pitoaudiovisual
Copper - Posts: 388
Posted: February 06, 2012 at 3:17 PM / IP Logged
yeah i reset the system and now the car light is off. I think the customer did somthing wrong but anyways the only concern is the key light is still lite but only in gear. when the car is parked no key light but when put into drive or reverse the light comes on.
pts760
Copper - Posts: 403
Posted: February 06, 2012 at 3:33 PM / IP Logged
Are they putting the vehicle in gear before the remote start is disengaged?
I drink current, eat ohms, and bleed voltage
pitoaudiovisual
Copper - Posts: 388
Posted: February 06, 2012 at 3:57 PM / IP Logged
no what im doing is, the car is remote started and i told the customer to turn the car off with the remote before they get in the car then start the car normally. It doesnt show up until the car is in drive or reverse
extreme1
Posted: February 06, 2012 at 5:01 PM / IP Logged
I already told you how to fix it.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
pitoaudiovisual
Copper - Posts: 388
Posted: February 06, 2012 at 8:24 PM / IP Logged
i checked all the wires under the hood by colors and then by diagram and they all look good and i also checked both ign + and -  as well as both acc wires..
12vericg
Posted: February 11, 2012 at 10:21 AM / IP Logged
I had the same problem on a 2011 Infiniti QX56. Turned out I forgot the diode on the underhood relay on the neutral safety wire. Hope that helps
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
