remote start on 2009 ford e 150
sparkyssb
Copper - Posts: 205
Posted: February 08, 2012 at 2:27 PM / IP Logged
Hello. I am in need of a wiring diagram for an 2009 Ford Econoline Van. (E-150) Also need to know if a bypass is required for this vehicle. If so, what units would work?
Thanks!
Platinum - Posts: 7,783
Posted: February 08, 2012 at 4:14 PM / IP Logged
Here is a link to the wiring info from DEI : http://www.readyremote.com/main.asp?make=Ford&model=E-Series
Will need a bypass.  There are several good data style bypass modules available.  DEI PKALL, Fortin Key-Override-All and  iDatalink ADS TBSL KO.
Another option is the DEI 1100F.  Discontinued but usually available "online" for less than $20.  Install guide in the Downloads section.
smokeman1
Platinum - Posts: 1,588
Posted: February 08, 2012 at 9:13 PM / IP Logged
Might want to get a cheap two dollar key made for the vehicle to see if you need a bypass module. If it starts and runs with the cheap key, no bypass module needed.   I installed a remote starter in my work van, 2008 E-150, and did not need a bypass unit, even though the wiring guides indicated the need for one.
sparkyssb
Copper - Posts: 205
Posted: February 09, 2012 at 8:42 AM / IP Logged
Thanks kreg and smokeman. I'm going to see if I need a bypass first using the cheap key method but if I do, I think the XK05 would be my choice. (Best price because I can't find a DEI 1100F)
I wanted to post the wiring from the the DEI site so others searching the forums in the future can find it.
12volts
red (fusible link B or G)      +      SJB, black 1 pin plug (G), pin 1
Starter
blue/white      +      ignition switch, gray 13 pin plug, pin 5
Second Starter
N/A
Ignition
WHITE/ orange      +      ignition switch, gray 13 pin plug, pin 1
Second Ignition
N/A
Third Ignition
N/A
Accessory
BROWN / yellow      +      ignition switch, gray 13 pin plug, pin 8
Second Accessory
PURPLE / green      +      ignition switch, gray 13 pin plug, pin 3
Keysense
blue/gray      -      ignition key switch, brown 6 pin plug, pin 1
Power Lock
gray / YELLOW      -      driver kick or SJB, gray 26 pin plug (C), pin 17
Power Unlock
PURPLE / gray      -      driver kick or SJB, gray 26 pin plug (C), pin 4
Lock Motor
gray/brown      5 wire      driver kick or SJB, black 32 pin plug (D), pin 6
Unlock Motor
blue/green      5 wire      driver kick or SJB, black 32 pin plug (D), pin 28
Parking Lights+
PURPLE / white      +      driver kick or SJB, gray 13 pin plug (E), pin 6
Parking Lights-
gray      -      headlight switch or SJB, black 52 pin plug (B), pin 31
May need to interrupt the headlight switch ground when triggering this wire. It is BLACK/ blue at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Hazards
BROWN / yellow      -      hazard switch or SJB, black 52 pin plug (B), pin 48
Turn Signal(L)
blue/green (F); gray/brown (R)      +      SJB, black 26 pin plug (F), pin 21; black 32 pin plug (D), pin 25
Turn Signal(R)
yellow/purple (F); PURPLE / orange (R)      +      SJB, black 26 pin plug (F), pin 23; black 32 pin plug (D), pin 26
Reverse Light
blue/white      +      driver kick, harness to rear
Door Trigger
GREEN/ purple      -      driver kick or SJB, gray 26 pin plug (C), pin 14
Dome Supervision
gray/purple      +      driver kick or SJB, gray 14 pin plug (A), pin 9
Trunk/Hatch Pin
green (rear cargo doors)      -      driver kick or SJB, gray 26 pin plug (C), pin 3
Hood Pin
N/A
Trunk/Hatch Release
N/A
Power Sliding Door
N/A
Factory Alarm Arm
N/A
Factory Alarm Disarm
N/A
Disarm No Unlock
N/A
Tachometer
NOT blue      ac      any fuel injector
Notes: On diesel models, use the camshaft position sensor wire, which is orange at the PCM, middle plug, pin 43. The PCM (Powertrain Control Module) is on the driver side of the engine.
Wait to start
N/A
Brake Wire
PURPLE / white      +      brake switch or SJB, black 52 pin plug (B), pin 40
Parking Brake
WHITE/ purple      -      parking brake switch or SJB, gray 26 pin plug (C), pin 1
Horn Trigger
blue/white      -      horn switch or SJB, black 52 pin plug (B), pin 41
Notes: The SJB (Smart Junction Box) is under the driver dash.
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
