igition controlled lock/unlock 03 crv dei
12voltboy
Member - Posts: 15
Posted: February 18, 2012 at 12:21 PM / IP Logged
03 Honda CRV- Avital 4103 and ads dlsl ha
Installed above and can’t get the ignition controlled lock/unlock (menu 1 feature 2&3) to work. It is a feature I like and have had it on several other installs.
When installing above, I could not get the ADS door lock data to work. Thought I had the right wire but must not have, so I disconnected it and went to the traditional driver kick wires.
Otherwise, followed both manuals and everything else works as it should. So the ADS does the bypass and the dei does everything else.
When I try to program for ignition controlled lock/unlock and advance through the options, I always get two beeps, even if I should be on option one, and therefore only get one beep.
Any ideas?
There are absolutely only two kind of people in the world – Those who absolutely believe there are only two kind of people in the world and those who don’t.
smokeman1
Platinum - Posts: 1,588
Posted: February 19, 2012 at 7:06 AM / IP Logged
Are you sure you are getting to the right menu?
Ignition on then off...press and hold the program button until the LED blinks once and horn honks once...release the button..press the button two times and release, then press and hold..the LED should flash twice for the feature 2... use the remote to change the option.
Not sure what you mean when you say.. I always get two beeps, ..............and therefore only get one beep.
offroadzj
Gold - Posts: 2,043
Posted: February 19, 2012 at 9:24 AM / IP Logged
When you get into the menu option for the ignition controlled locks, you should be pressing the lock button to choose option 1. It won't advance through by pressing unlock. Its lock for option 1, unlock for option 2, button 3 for option 3, etc.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
12voltboy
Member - Posts: 15
Posted: February 19, 2012 at 2:02 PM / IP Logged
Thanks guys . . . it was operator error.
Smokeman1, What I meant about two beeps vs. one beep is a result of my not knowing it is lock for option 1, unlock for option 2.
Kenny, thanks for making that clear.
I kept pressing unlock only and so I always got 2 flashes / beeps. But then it never seemed to “take” even though I was looking for option 2. This time I went lock for 1 and then unlock for 2 and this then “took”.
Working fine now.
As always, I very much appreciate the help.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
