97 olds aurora, dash lights out
reecegr
Member - Posts: 28
Posted: February 19, 2012 at 1:51 PM / IP Logged
A friend of mine connected the dimmer wire to a ground on a 97 olds aurora,And guess what!!!! the dash lights only work with the auto headlights off.I have checked all fuses and relays with no luck.any sugg. would be great
Thanks in advance
Platinum - Posts: 13,674
Posted: February 19, 2012 at 4:19 PM / IP Logged
Look harder for a blown fuse.  I will check for fusebox locations for you.  Until then, which fusebox did you check?
Posted: February 19, 2012 at 4:38 PM / IP Logged
Step Action Value(s) Yes No
1 Did you perform the Interior Lights Dimming System Check? Go to Step?2 Go to Interior Lights Dimming System Check
2
1. Disconnect the instrument panel (IP) compartment lamp switch connector.
  2. Turn the ignition switch to the RUN position.
  3. Connect a fused jumper between the IP compartment lamp switch connector terminal?B (BLK) and ground.
Does the IP compartment lamp light?
Go to Step?3 Go to Step?4
3 Test CKT?150 (BLK) for an open. Refer to Testing for Continuity in Wiring Systems.Is CKT?150 OK? Go to Step?8 Go to Step?7
4 Test CKT?39 (PNK) for an open or a short to ground between S215 and the IP compartment lamp. Refer to Testing for Continuity or Testing for Short to Ground in Wiring Systems.Is CKT?39 OK? Go to Step?5 Go to Step?7
5 Test CKT?157 (GRY) for an open. Refer to Testing for Continuity in Wiring Systems.Is CKT?157 OK? Go to Step?6 Go to Step?7
6 Replace the IP compartment lamp. Refer to Instrument Panel Compartment Lamp Replacement or Instrument Panel Compartment Lamp Replacement .Is the repair complete? Go to Interior Lights Dimming System Check
7 Repair the suspect wiring. Refer to Wiring Repairs in Wiring Systems.Is the repair complete? Go to Interior Lights Dimming System Check
8 Replace the IP compartment lamp switch.Is the repair complete? Go to Interior Lights Dimming System Check
reecegr
Member - Posts: 28
Posted: February 19, 2012 at 4:39 PM / IP Logged
under the back seat 2 locations, next to the drivers left knee under dash and under hood behind passenger headlight. checked every fuse wit a meter.
Thanks for the reply
reecegr
Member - Posts: 28
Posted: March 04, 2012 at 3:20 PM / IP Logged
Thanks for the repl, it ended up being the rheostat for the lighting.
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
