2010 Dodge Ram Reverse and VSS Wires
gneto
Posted: February 23, 2012 at 4:44 AM / IP Logged
 I'm installing a Pioneer Avec z130bt. I have a 2010 Dodge ram 1500 quad Cab. I'm looking for the color and location of the reverse gear wire and VSS Wire. I beleive the VSS wire is located at the PCM at passenger side, under hood Dark GREEN/ Brown in harness closest to drivers side. there are four plugs at that PCM. Trying to confirm before I tap it. Secondly, I  beleive the backup lights are WHITE/ light green wire in harness under drivers side hood. I believe I can tap that for the reverse wire. Can someone confirm if my research is correct on the colors and locations. Would sure help me out alot.... Thanks Glenn
ropuma
Copper - Posts: 102
Posted: February 27, 2012 at 8:45 PM / IP Logged
PCM, plug towards driver side, pin 32 dark green-brown (vss)
Reverse wire white-red
2010 Dodge Ram Reverse and VSS Wires - Last Post -- posted image.
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
