normally open door triggers
Kcautosound
Member - Posts: 33
Posted: February 23, 2012 at 7:38 AM / IP Logged
Hey guys. In a jam here. Normally on a 06 Fusion I would grab the blue positive dome light wire for door trigger but this time there's a conflict. Im installing a Compustar remote start alarm into this lady's manual transmission Fusion. What happens is after you set it up for reservation mode and close the door the car turns off like it should and then the stupid dome light kicks on for some reason. This then kicks it out of reservation mode.
Im needing to know how I connect normally open door triggers. In my 20 years of installing I would think that I've come across these but im a little stumped. Any help would be great.
Kcautosound
Member - Posts: 33
Posted: February 23, 2012 at 10:16 AM / IP Logged
Got it figured out with registers and diodes
tedmond
Gold - Posts: 4,610
Posted: February 24, 2012 at 10:15 AM / IP Logged
you could have put a diode on the domelight wire, and set the domelight delay to auto.
Ted
Compustar Expert
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
