which spl woofer for my single cab
sc09taco
Member - Posts: 6
Posted: March 05, 2012 at 6:20 PM / IP Logged
I have a single cab 2009 toyota tacoma, I plan to enter either single 12 or single 15 class, ive been looking at fi, digital designs, sundown audio, im open to all sugestions and comments
sc09taco
Member - Posts: 6
Posted: March 05, 2012 at 9:22 PM / IP Logged
Please comment if you have done/ seen similar applications, what worked wat didnt work
rfhvhtoo
Copper - Posts: 238
Posted: March 07, 2012 at 2:06 AM / IP Logged
Do you know how much mounting depth you'll have in your enclosure? will it be ported or sealed? do you know how much Volume you'll have?
You can't really choose/suggest a subwoofer without these vital specifications of the box you'll be using because every subwoofer is different.
I can't hear you!
sc09taco
Member - Posts: 6
Posted: March 07, 2012 at 5:41 PM / IP Logged
I dont have much space so its going to sit on the passenger half of my bench seat and the passenger foot space, id say my moubting depth would probably be anything under 14 inches maybe a little more
sc09taco
Member - Posts: 6
Posted: March 07, 2012 at 5:42 PM / IP Logged
Ported enclosure
soundnsecurity
Gold - Posts: 2,711
Posted: March 07, 2012 at 8:20 PM / IP Logged
ok that bit of information changes everything cuz im sure everybody thought you wanted something to fit behind the seat. spl and small spaces dont typically go together. in that case you should have at least 2.5 cubic feet to work with. what is your budget and what kind of power do you want to have? what upgrades in your charging system do you plan on doing?
if you plan on competing with this system then here are some things to think about .depending on which competitions you plan to attend they might class you out by woofer size or power class. so that is something to think about when planning your system because you dont want to have 4000W on a single 12 when you are competing against someone with two 18's on 4000W.
sc09taco
Member - Posts: 6
Posted: March 07, 2012 at 8:36 PM / IP Logged
I think theres more like 4 cubic feet available if not more, as far as budget and power I plan on running anywhere from 1000-3500 rms and make whatever upgrades to the electrical system that are needed, also would apreciate amp suggestions
sc09taco
Member - Posts: 6
Posted: March 07, 2012 at 8:42 PM / IP Logged
Ive been talking to the guys that run the comp up here and the class is based on woofer size and count
rfhvhtoo
Copper - Posts: 238
Posted: March 07, 2012 at 11:59 PM / IP Logged
I know they also take into account in certain competitions the height of the box, battery count, alternator count.
for example:
http://www.soundoff.org/rules.htm there's also other rules above the word USACi CLASSES & DIVISIONS in Adobe PDF
http://www.iasca.com/page/WebsiteMembers
for an SPL setup this is just what I would recommend for a Pretty intense SPL system without too much on the pocket. and ALWAYS READ REVIEWS.
MOFO is a GREAT Budget SPL subwoofer & a solid Amplifier to go with it
http://www......com/item_23547_Hifonics-Brutus-BRZ1700.1D.html
Good SQ and Extremely good SPL subwoofer and great amps.
http://www......com/item_18014_Orion-2010-HCCA152.html
http://www......com/item_4115_MA-Audio-HK15X2.html
http://www......com/item_23549_Hifonics-Brutus-BRZ2100.1D.html
High SPL very worthy subwoofer
http://www......com/item_11344_Kicker-Solo-Baric-S15L72-08S15L72.html
http://www......com/item_23875_MB-Quart-ONX1.1500D.html
http://www......com/item_23548_Hifonics-Brutus-BRZ1200.1D.html
There are also companies like FI BTL, AscendantAudio, that have Insane SPL. look into those and the BOX Specifications they have.
I put the Amps with the subwoofers I thought fit best IMO. Also do the Big 3 upgrade to your electrical system (with 0-gauge wire), Look it up on The12volt and also on google. I should have a thread on here about How to do my BIG 3. Have/get a relatively new engine bay battery and looking at the Power you want to also add a Battery in your trunk next to your amp with a RELAY in between the two.
If applicable get an High Output Alternator before the New batteries or at the same time.
Goodluck!!
I can't hear you!
