subwoofer wiring
brettrp
Posted: April 01, 2012 at 5:02 PM / IP Logged
i have 2 mtx thunder 9500 svc subs and want to run them off my soundstream rub1.2500 monoblock , is it ok to wire both subs to the single channel?
Platinum - Posts: 13,671
Posted: April 01, 2012 at 5:43 PM / IP Logged
What is the impedance of the woofers?   What is the minimum safe operating impedance of the amplifier?
wheelerdr
Copper - Posts: 337
Posted: April 02, 2012 at 1:34 AM / IP Logged
I would say yes that amp is 1 ohm stable.
jason111
Posted: May 01, 2012 at 10:54 AM / IP Logged
If your sub is a SVC then its 4 ohm, so if you have 2 of them it would be 2 ohm at the amp. Being that amp is a mono block, there is only one channel anyways.
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
