control wiring diagram anyone?
jj1960
Posted: April 08, 2012 at 5:44 AM / IP Logged
can anyone sort this out for me . i cannot get my head around it
i need a wring diagram to do the following
i have a  fan controller that operates a fan when it reaches a certain temperature ,instead of the fan i want it to operate an 12 volt 2 wire actuator
when the desired temperature is reached the power comes on and the actuator will open , when the temperature drops the power to the actuator will be cut .and  i need the actuator to  then close by having the polarity reversed and getting the power to do this from somewhere  . is this possible
i hope you can understand what i am asking and give me a solution
thanks
hotwaterwizard
Silver - Posts: 1,350
Posted: April 08, 2012 at 7:53 PM / IP Logged
There is a way to do it but you need th be able to stop the action when the actuator reaches it's full extension and retraction. Micro switches are commonly used for this.
control wiring diagram anyone? - Last Post -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
jj1960
Posted: April 09, 2012 at 2:05 AM / IP Logged
i couldn't see the wood for the trees
must have had brain freeze or something
thankyou very much
hotwaterwizard
Posted: April 16, 2012 at 7:38 PM / IP Logged
Please Let me know if the diagram works.
Stockton California
jj1960
Posted: February 04, 2013 at 10:26 AM / IP Logged
sorry for taking so long to get back to you but thought i would let you know that it works lovely
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
