2011 subaru impreza remote start wiring
smc0922
Member - Posts: 14
Posted: May 01, 2012 at 8:23 PM / IP Logged
As the title states. Any data override info would be extremely helpful as well.
-Shawn
AIM: Creegman9695
tommy...
Gold - Posts: 1,901
Posted: May 02, 2012 at 8:49 AM / IP Logged
2011 Subaru Impreza     DirectWire 2.0 Vehicle Information
Remote Start
Item     Wire Color     Polarity     Wire Location
12 Volts     white (50A)     +     ignition switch, white 6 pin plug, pin 3
Second 12 Volts     N/A
Starter     WHITE/ black     +     ignition switch, white 6 pin plug, pin 2
Second Starter     WHITE/ red     +     ignition switch, white 6 pin plug, pin 6
Ignition     green     +     ignition switch, white 6 pin plug, pin 1
Second Ignition     N/A
Third Ignition     N/A
Accessory     blue     +     ignition switch, white 6 pin plug, pin 4
Second Accessory     yellow     +     ignition switch, white 6 pin plug, pin 5
Third Accessory     N/A
Keysense     BLACK/ white     +     BIU, white 30 pin plug, pin 2
The BIU (Body Integrated Unit) is under the driver dash, to the right of the steering column.
Data Bus     YELLOW /GREEN (keyless entry communication)     data     BIU, gray 35 pin plug, pin 24
Can Bus High     pink     data     BIU, gray 35 pin plug, pin 1
The BIU (Body Integrated Unit) is under the driver dash, to the right of the steering column. The security light wire is BROWN / red (-) at the BIU, gray 35 pin plug, pin 10.
Can Bus Low     lt. GREEN/ red     data     BIU, gray 35 pin plug, pin 9
Can Bus Sw     N/A
Power Lock     lt. green     -     BIU, gray 35 pin plug, pin 15
Power Unlock     blue/black     -     BIU, gray 35 pin plug, pin 29
Lock Motor     lt. GREEN/ YELLOW     5 wire     BIU, gray 35 pin plug, pin 7
Driver Unlock Motor     RED / green     5 wire     BIU, gray 35 pin plug, pin 23
Parking Lights (-)     BLACK/ white     -     BIU, gray 26 pin plug, pin 11
Parking Lights (+)     BLACK/ white     +     dash fuse box, white 20 pin plug, pin 12
Hazards     green     -     BIU, white 28 pin plug, pin 22
Turn Signal (Left)     WHITE/ red     +     dash fuse box, white 20 pin plug, pin 20
Turn Signal (Right)     gray     +     dash fuse box, white 20 pin plug, pin 3
Headlight     blue/black     -     BIU, white 28 pin plug, pin 8
AutoLights     N/A
Reverse Light     BROWN / yellow     +     passenger kick, white 12 pin plug, pin 3
Left Front Door Trigger     blue/orange     -     BIU, gray 35 pin plug, pin 19
Right Front Door Trigger     blue/white     -     BIU, gray 35 pin plug, pin 32
Left Rear Door Trigger     yellow/white     -     BIU, gray 35 pin plug, pin 20
Right Rear Door Trigger     WHITE/ red     -     BIU, gray 35 pin plug, pin 6
Dome Supervision     GREEN/ yel (dome light), BLACK/ wht (spot map light)     -     BIU, white 30 pin plug, pins 5 and 4
Trunk/Hatch Pin     yellow/blue     -     BIU, gray 35 pin plug, pin 33
Rear Glass Pin     N/A
Hood Pin     yellow/black     -     hood switch, white 2 pin plug, pin 1
Trunk/Hatch Release     GREEN/ red (wagon only) (rear handle switch)     -     BIU, white 28 pin plug, pin 24
The BIU (Body Integrated Unit) is under the driver dash, to the right of the steering column. On the sedans, use the trunk release motor.
Trunk Release Motor     BLACK/ blue (sedan and wagon)     5 wire     BIU, gray 35 pin plug, pin 22
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with driver door open
Factory Alarm Disarm     see disarm no unlock
Disarm No Unlock     Transponder, ignition, and keysense
Trunk Alarm Shunt     N/A
Tachometer     gray/red     ac     instrument cluster, white 40 pin plug, pin 32
On non-turbo models, can also use BROWN / yellow, GREEN/ orange, BLACK/ red, or orange at any fuel injector, gray 2 pin plug, pin 1. On turbo models, can also use white, BLACK / YELLOW, BLACK/ red, or BLACK/ blue at any fuel injector, gray 2 pin plug, pin 2. On STI models, can also use GREEN / WHITE, blue/white, white, or BROWN / red at any fuel injector, gray 2 pin plug, pin 2.
Wait to Start     N/A
Neutral Safety     GREEN/ black (M/T)     -     Engine Control Mod below glove box, wht 35 pin plug (C), pin 35
Clutch Pedal     blue/white (input), BLACK/ blue (output)     - N.O.     clutch switch, white 2 pin plug, pins 2 and 1
Fuel Pump     RED / black     +     passenger kick, white 12 pin plug, pin 4
Rear Defroster     GREEN/ YELLOW     -     BIU, gray 35 pin plug, pin 16
Mirror Defroster     same as rear defroster
Left Front Heated Seat     lt. green (L), RED / blue (H)     5 wire     LH seat heater switch, blue 4 pin plug, pins 1 and 4
Right Front Heated Seat     white (L), RED / white (H)     5 wire     RH seat heater switch, white 4 pin plug, pins 1 and 4
Speed Sense     pink/green     ac     instrument cluster, white 40 pin plug, pin 31
Brake Wire     lt. green     +     BIU, gray 26 pin plug, pin 2
Parking Brake     gray     -     BIU, white 28 pin plug, pin 15
Horn Trigger     red     -     BIU, white 30 pin plug, pin 29
Wipers     RED / blue (L), BLACK/ blue (H), yel/blk (ignition)     +     wiper switch, white 18 pin plug, pins 7, 8, and 17
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
M.E.C.P & First-Class
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
