08 dodge charger
Tintnmoreok
Member - Posts: 21
Posted: May 07, 2012 at 8:36 AM / IP Logged
this car has a 5 wire horn system.  how do I connect the horn to the keyless entry?
Tint 'N More
Posted: May 07, 2012 at 2:42 PM / IP Logged
5 wire horn system? WTH are you smoking?*
Power control module under hood, driver side.
Black 15 pin plug, pin 3 dark GREEN/ orange (+).
* If you had a 5 wire system it would suck as well as blow 08 dodge charger - Last Post -- posted image.
Tintnmoreok
Member - Posts: 21
Posted: May 07, 2012 at 4:54 PM / IP Logged
Thanks for the feedback, Howie.  I heard back from Omega and the 5 wire system in this car required a relay and wiring the same as a 5 wire trunk release.  I did that and it worked just fine.  Are you saying if I had just converted my negative output from the keyless to a positive it would have worked as well?
thanks again
Tint 'N More
Posted: May 07, 2012 at 5:14 PM / IP Logged
Yes!
Posted: May 07, 2012 at 5:19 PM / IP Logged
I gave you DEI, meanwhile Audiovox gives a light blue/green (-)at the fusebox. Rather confusing but worth looking for and testing.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
