12volts pink/black & red + ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition blue + ignition harness
Second Ignition GREEN/ red (20 awg) + ignition harness
Third Ignition
Accessory BLACK/ orange + ignition harness
Second Accessory BLACK/ white + ignition harness
Keysense
Power Lock WHITE/ green + conn. C4, pin 15 @ BCM
Notes: Lock requires a positive trigger thru a 1800 ohm resistor. Unlock requires a positive trigger thru a 750 ohm resistor. MUST use relays.
The BCM (Body Control Module) is attached to the fuse/relay box at the end of the dash on the driver side. Connector C4 is a 26 pin plug on the bottom edge of the BCM.
Power Unlock same wire as power lock
Lock Motor ORANGE / black 5wi conn. C4, pin 9 @ BCM
Notes: The BCM (Body Control Module) is attached to the fuse/relay box at the end of the dash on the driver side. Connector C4 is a 26 pin plug on the bottom edge of the BCM.
Unlock Motor blue/white 5wi conn. C4, pin 13 @ BCM
Parking Lights+ BLACK / YELLOW + headlight switch or DKP
Door Trigger - conn. C4 @ BCM
Notes: The driver door trigger is tan in pin 5, the front passenger door is tan/red in pin 6, the left rear door is tan/orange in pin 7, and the right rear door is tan / YELLOW in pin 8. Use all four wires and diode isolate each.
Dome Supervision use door trigger
Trunk/Hatch Pin tan/black - conn. C4, pin 18 @ BCM
Trunk/Hatch Release BLACK/ white 5wi conn. C4, pin 1 @ BCM
Factory Alarm Arm lt. GREEN/ orange + conn. C4, pin 4 @ BCM
Notes: Arm requires a positive trigger thru a 1800 ohm resistor. Disarm requires a positive trigger thru a 750 ohm resistor. MUST use relays.
Factory Alarm Disarm same wire as alarm arm
Disarm No Unlock see factory alarm disarm
Tachometer NOT GREEN/ lt. green ac any ign. coil or fuel injector
Brake Wire WHITE/ tan + brake pedal switch
Horn Trigger BLACK/ red - steering column
Immobilizer By Pass : Not Available
"how will i connect the voilet/black -channel 4 output to my car radio so i can controll it threw my remote.???"
---- wire a relay as follows:
86 - fused constant +12v
85 - violet/black
87 - fused constant +12v
87a - hot side of radio acc wire.
30 - radio side of radio acc wire
"also i have a single wire system for my lock and unlock will i need to use relays for resistors????"
---- yes, you need to use relays.
"Do i need a relay for the factory disarm.???"
---- yes, its positive trigger
If you don't have much experience doing remote start/alarms, then this is a tough vehicle due to all the resistors/relays needed.
