2012 Acura TL Car Stereo Wiring
dyrtyred
Posted: June 06, 2012 at 6:23 PM / IP Logged
Hello,
I'm looking a wiring diagram for a 2012 Acura TL w/ Navigation so I can add an aftermarket amp to the system by splicing into the factory amp speaker wires. The front and rear speaker wire colors would be alot of help!!
Thanks in advance!!!
Platinum - Posts: 13,667
Posted: June 06, 2012 at 10:17 PM / IP Logged
Can you see the colors of the wires on the speakers mounted in the rear deck?
dyrtyred
Posted: June 07, 2012 at 3:39 AM / IP Logged
If I remove the trunk trim I probably can but I want to tap into the signal coming from the factory amp connector in the trunk. Sorry about not saying that.
awdeclipse
Copper - Posts: 285
Posted: June 07, 2012 at 7:21 AM / IP Logged
If you can see the color of the wires at the rear speakers, then you can look for the same colors at the amp connector (where you want to splice in)
Posted: June 08, 2012 at 2:31 AM / IP Logged
I think the OP meant signal going TO the amp, not FROM it, sorry about that Mr. awdeclipse.
In which case look behind the head unit, then meter the wires at amp.
