auto sensing remote turn on amps
jacktheripper
Posted: June 07, 2012 at 5:23 PM / IP Logged
what brands offer it and not sure how new of a feature this is but whats the big deal about it? am i missing something or does it jus save you from running a remote turn on wire?
Platinum - Posts: 13,673
Posted: June 07, 2012 at 6:39 PM / IP Logged
It is a helpful feature when installing an amp into a Newer GM vehicle (while retaining the OEM deck)  that allows the radio to remain on after turning the key off.  Normally you would catch an ACC wire, these vehicles do not have a wire that remains on after the key is turned off.
Pac-audio.com makes a Line Out Converter that has this circuitry built into it.  SOEM-T is the model number.
Bazooka has used this technology for years on their amplified bass tube.  JL had it on the first generation of the 500/1, the unique thing about that amp was that when using it, the amp's remote wire became a remote output to turn on the other amplifiers on the system.
jacktheripper
Posted: June 07, 2012 at 9:21 PM / IP Logged
Thanks for the info.
jason111
Posted: June 12, 2012 at 8:31 AM / IP Logged
MTX has it in some of their amps and Thunderforms.
