03 toyota highlander
rfwave
Copper - Posts: 120
Posted: August 11, 2012 at 1:21 PM / IP Logged
doing R/S, Data mode or Hardwire mode, don't know which way is better ?
Posted: August 11, 2012 at 2:39 PM / IP Logged
Hardwire, more reliable, especially for tach which should be at pin 9 on your diagnostic (OBD 2) socket.
Platinum - Posts: 7,783
Posted: August 11, 2012 at 2:42 PM / IP Logged
W2W ( hardwire ) mode always works.   For that vehicle it's only a transponder bypass function, so we are only talking about 3 wires ( +12V, ground and GWR ) that have to be run ( instead of the D2D cable ).  Some bypass modules include the Keysense wire, other use the R/S's GWR to handle it.
For a better answer we would need to know the R/S make & model and the bypass module used.
rfwave
Copper - Posts: 120
Posted: August 11, 2012 at 3:40 PM / IP Logged
Thanks UK, US. (Autostart + idatalink)
racerjames76
Silver - Posts: 581
Posted: August 14, 2012 at 12:29 PM / IP Logged
As long as you can make solid connections, hardwiring is always the best method. How many times do you want to go back under your dash? I personally would rather take an extra 15 minutes during the install knowing that I won't be going back in there, and if I do it will be MUCH easier to diagnose a hardwired install than a data install. How do you test what the bypass and alarm are saying to each other if you can't see the communication in simple 12v/ground signals?
On top of that idatalink/flashlogic always tells you when you call for tech support, if you are using D2D to switch to hardwired method before they can help you. 03 toyota highlander - Last Post -- posted image.
To master and control electricity is perfection. *evil laugh*
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
