kicker kx 600.1 mono amp
terry osborn
Copper - Posts: 54
Posted: August 28, 2012 at 5:42 PM / IP Logged
Well...After 7 years of abusive treatment,my Kicker amp finally laid down. It's still got a pulse,and with some help I believe it's worth saving.
No output to the sub.12vdc is available at the power lugs.12vdc is available at remote lug. Both 30 amp onboard ATC fuses are good and power flowing thru.Protection circuit LED is off and Power on LED is on.Amp cover has been removed to check for burned components,overheating and broken solder joints with none found.RCA's are putting signal to the amp.Sub-woofer and wiring checks good.I have not removed the heatsink clamps or tried to remove the boards,so inspection to the bottom of board was with inspection mirror and flashlight. Any help with this would be greatly appreciated.
I've noticed one thing about "Experts". When one shows up,someone gets hurt!
Platinum - Posts: 13,725
Posted: August 28, 2012 at 6:01 PM / IP Logged
Is there a relay mounted on the circuit board very near the speaker output terminals? A few seconds after the amp turns on, can you hear that relay click?
Have you checked your speakers and wiring to the speakers? Disconnect the speaker wire from the amp. Touch and hold the negative speaker wire to the Ground terminal of the amp, not the negative speaker terminal, but the ground connection by the Power and remote terminals. Then briefly touch the positive speaker wire to the power terminal of the amp. Does the speaker(s) make a sound?
terry osborn
Copper - Posts: 54
Posted: August 28, 2012 at 8:39 PM / IP Logged
Must be my lucky day...You helped me repair the Kicker 650.4 channel amp in my truck like....4 years ago? And remember the inverter with the bad rectifier in my race car trailer? Still workin' LIKE A NEW ONE!
Checked the sub and wiring first..All good. Yes,there's a relay at the speaker terminals,and I don't hear and audible click when the amp powers up.The relay is located below a companion board that has the RCA'S,amp strapping jacks,gain,freq and bass boost controls.Board is attached with 3 screws and has a 5 pin push-in connector.
Posted: August 28, 2012 at 9:20 PM / IP Logged
There is a transistor that fails and keeps the relay from energizing. I will check with my friend to see if he has pictures of that amp and maybe we can remember where that transistor is located. I will check with him Thursday. Or if I get out in the storm tomorrow I will go by.
terry osborn
Copper - Posts: 54
Posted: August 29, 2012 at 10:39 AM / IP Logged
Yes Sir.....You stay out of harms way with that Hurricane. I've got pictures of the amp circuit boards if you need them.
Posted: September 08, 2012 at 9:03 PM / IP Logged
Remind me again if you do not hear from me by Noon Sunday. Sorry.
Posted: September 09, 2012 at 4:41 PM / IP Logged
There are several problems that could cause the relay not to energize. Most common is a bad solder joint on the relay itself. Can you remove the board from the heatsink and see if that is the case?
terry osborn
Copper - Posts: 54
Posted: September 10, 2012 at 11:44 AM / IP Logged
Removed the board and didn't find any obvious cracked solder joints on relay or anywhere else. I did resolder joints to relay and 10 others that were questionable. Still won't fire relay.
Posted: September 10, 2012 at 11:50 AM / IP Logged
I read the e-mail he sent me and this is what it said.
The relays fail. The D-K part number PB-1132 works in this amp. Tell him to confirm that the relay is getting 12v to the coil before ordering the relay.
D-K = Digi-Key
Posted: September 10, 2012 at 11:53 AM / IP Logged
With the amp unmounted from the heat sink, do not leave it powered up any longer than necessary. Have your meter set and leads ready to touch the contacts when you turn it on. 15 to 20 seconds max.
