2 kicker 15cvx's on jl hd1200/1
01ws6/tamu
Member - Posts: 44
Posted: September 20, 2012 at 10:35 PM / IP Logged
From those of you who have these subs or those of you who sell and install them daily.
What is your opinion in a non competition setting on using the JL 1200/1 on these subs will it be sufficient.
It won't be a competition system it will mainly be listened to at sane levels most of the time for daily driver duties. BUT when I want it to hit will this amp deliver the goods sufficiently or should I buy another and do one amp per sub. These subs are the dual 4 ohm coil cvx's and will be in a truck with a bed cut.
01ws6/tamu
Member - Posts: 44
Posted: September 20, 2012 at 10:36 PM / IP Logged
I already own the amp so it's a pre existing piece of equipment.
DYohn
Moderator - Posts: 10,741
Posted: September 21, 2012 at 11:59 AM / IP Logged
I recommend completing your installation.  Use the amp you have.  Listen to it.  If it's not what you want, then you can decide what upgrades you need.
Platinum - Posts: 13,670
Posted: September 21, 2012 at 12:31 PM / IP Logged
You must wire the voice coils of each driver in series. Then parallel the speakers at the amp. That amp will not run at below 1.5 ohms.
01ws6/tamu
Member - Posts: 44
Posted: September 21, 2012 at 5:18 PM / IP Logged
10-4
01ws6/tamu
Member - Posts: 44
Posted: September 26, 2012 at 12:43 AM / IP Logged
Anyone care to volunteer how they think the 1200/1 JL amp will work with 2 of the kicker cvx 15's
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
