deleting remotes clifford 50.5x
rt4x4
Copper - Posts: 107
Posted: October 09, 2012 at 7:09 PM / IP Logged
I am on my 4th remote on my 50.5x and I was wanting to know how to delete all remotes, or how to make 2 more slots open to recieve new remotes, Do you go through the valet way and press the valet button 14 times,does that delete all remotes or just delete 1 slot. I just need to delete 2 slots,damaged remotes.I always like to have a spare. Or just buy a bitwriter.
Platinum - Posts: 13,673
Posted: October 09, 2012 at 11:19 PM / IP Logged
Program the remote you have into the system 4 times. If you have 2 remotes, program each of those remotes twice each, in the following pattern, remote 1 then 2, then 1 then 2.
rt4x4
Copper - Posts: 107
Posted: October 09, 2012 at 11:55 PM / IP Logged
I am not sure exactly what you mean, I am wanting to delete 2 remotes that I dont use anymore , and add another that i like to keep as a spare
shortcircuit161
Silver - Posts: 556
Posted: October 10, 2012 at 8:32 AM / IP Logged
You will need to have all the transmitters (remotes) that you want programmed to the Clifford system (max of 4).
If you have the installation manual for the Clifford 50.5x, under the transmitter learn section, it will show you how to delete all the transmitters and reprogram any new ones. You can't just delete one.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
