jvc arsenal kd ahd79 won't turn on
fronzizzle
Copper - Posts: 57
Posted: October 16, 2012 at 7:41 PM / IP Logged
I purchased the above radio last March; in June, I installed it in my project car (1985 Camaro IROC Z). Everything worked fine, radio, all 4 speakers and amp/subs. At that point, I took the battery out and started doing the engine rebuild.
I finally got the engine installed and up and running last week. For the first time today, I tried turning the radio on again...nothing. I can't get it to come on. If you press the disc eject button, you here the "whirling" noise like it's trying to eject a disc. This will happen with the key on or off. I took this to mean that the power to the radio is fine, but I guess this might just be the constant power and not the ignition power.
I removed the face of the radio and used a paperclip to push the reset button. When it gets pressed & then you let up, the same disc eject "whirling" noise happens but the radio still won't turn on.
I checked all of the fuses in the car, none are blown.
I do have a 2-year warranty on the radio, so I can send it out for repair if needed. Before going through all that hassle, I wanted to make sure I'm not missing something. I called the vendor I purchased the radio through, they recommended checking the voltage at the red and yellow wire to make sure they are 12 volts. Other than that, they had nothing to add. I plan on checking this in the next day or two.
Platinum - Posts: 13,670
Posted: October 16, 2012 at 8:01 PM / IP Logged
Use a volt meter to make sure the radio's red wire has 12 volts on it when the key is in the ACC or ON position.
fronzizzle
Copper - Posts: 57
Posted: October 17, 2012 at 12:12 PM / IP Logged
That was my plan...hopefully, I'll get to that today or tomorrow.
If I'm getting power, is it safe to assume the radio needs repair?
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
