viper 5704 in toyota 2007 4runner sr5 v8
3 pin plug for locks, you are incorrect. The blue wire goes to green, 18pp, pin 8. The blue goes to blue, 18pp, pin 6, both in the DKP.These are the drivers door cylinder wires and will allow you to have 2 stage unlock just like the factory remote does. You will need to connect the blue 2nd unlock wire on your alarm together with the blue unlock wire above. I believe it is H 2/19 but i'll have to look it up to be sure.
Also, you need to connect the second ignition wire. Do this by connecting the pink/white to the blue / YELLOW on the ignition harness, and connecting RED / white to the white blue.
1. The object of connecting keysense is to disarm before it remote starts. Yor PKALL may alreay do this, i'm not familiar with it to know but most bypasses do.
2. No other relays or diodes needed. If BLACK / YELLOW H2/7 going to white is a supervision wire, would probably need a relay to work. Most alarms just have a milliamp output for this.
4. 3/6 is the supply for the ignition and gets a constant 12volts. 3/1 is the output and feeds the truck ignition from the RS. Wire it as shown.
3. the green is for negative trigger and purple is for positive trigger. Some Fords used positive, not your truck so don't use it.
Mike M2 Tech Manager CS Dealer Services1. What Chris means is you may decide not to connect the BLACK / YELLOW H2/7 at all due to the fact that when the Viper unlocks the truck the domelight will automatcally come on due to the way the truck itself operates. My suggestion is to not use the BLACK / YELLOW at all since it has little benefit.
2. Yes, that is what he is saying.
Also, you have pin 4 listed twice on the ignition harness, which of coarse can't be right. All the colors are correct tho...
Mike M2 Tech Manager CS Dealer ServicesI wanted to say that this is my goto thread for installing my Viper 4704v Remote Start with PKALL bypass and a 2102T module (Passive Keyless Entry) into my 2006 4Runner Sport.
The wires are literally the same expect my H3 harness... I don't have the alarm portion (my unit is just a remote start) so I don't have the H3/5 green wire and I don't have to cut the wire to my starter.But you guys have been a great help from the OP to all of the advice. This project is literally taking me no time at all because of all the advice here. I don't know what I'd do without this page.There are a few extra things I'm wiring up (a RadioShack piezo buzzer instead of my horn because I don't have a siren and I want a stock sounding chirp and can't use the toyota buzzer because it's controlled by the ECU), rear window up/down, sunroof open, defroster, etc. but I found those on other threads :)THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Search the12volt.com |
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
