2007 Acura TL Remote Start Wiring
bwright2112
Posted: November 12, 2012 at 10:01 AM / IP Logged
I was looking for the wire diagram for a 2007 Acura TL. The diagrams on here are for 06' and for 08' but some of the 08' TL are the 4th gen and mine is 3rd gen. I am installing Viper 5704 2 way alarm and remote start plus 529t sunroof module 530t window module, transponder bypass module and smart start just need to know if I can get a diagram for 07 or if a credible person can tell me it's ok to use 06 diagram
Thanks'
offroadzj
Gold - Posts: 2,043
Posted: November 12, 2012 at 10:28 AM / IP Logged
Here is the readyremote.com diagram for the 07. It does not show windows though.
DIRECTWIRE™ WIRING INFORMATION - ACURA / TL / 2007 / Remote Start
[PRINT THIS PAGE]
12volts      white (50A)      +      ignition switch, brown 7 pin plug, pin 3
Starter      black      +      ignition switch, brown 7 pin plug, pin 1
Second Starter      N/A
Ignition      BLACK / YELLOW      +      ignition switch, brown 7 pin plug, pin 6
Second Ignition      N/A
Third Ignition      N/A
Accessory      BLACK/ red      +      ignition switch, brown 7 pin plug, pin 4
Second Accessory      WHITE/ red      +      ignition switch, brown 7 pin plug, pin 5
Keysense      blue      -      left side of dash fuse box, green 30 pin plug, pin 13
Power Lock      pink/black (passenger door lock switch)      -      left side of dash fuse box, green 30 pin plug, pin 25
Power Unlock      pink/blue (passenger door lock switch)      -      left side of dash fuse box, green 30 pin plug, pin 9
Lock Motor      yellow/black      5 wire      dash fuse box, lt. green 12 pin plug, pin 12
Unlock Motor      YELLOW /GREEN      5 wire      dash fuse box, lt. green 12 pin plug, pin 2
Parking Lights+      RED / black      +      dash fuse box, white 45 pin plug, pin 31
Parking Lights-      RED / black      -      headlight switch in steering column cover
Hazards      GREEN/ red      +      left side of dash fuse box, green 30 pin plug, pin 28
Turn Signal(L)      RED / blue      +      dash fuse box, white 45 pin plug, pin 33
Turn Signal(R)      white      +      dash fuse box, white 45 pin plug, pin 27
Reverse Light      green      +      left of data link connector, white 20 pin plug, pin 19
Door Trigger      green      -      harness from back of dash fuse box
Dome Supervision      GREEN/ red      -      dash fuse box, rear, lt. green 5 pin plug, pin 4
Trunk/Hatch Pin      orange      -      left side of dash fuse box, green 30 pin plug, pin 24
Hood Pin      yellow/red or GREEN/ black      -      hood switch or under-hood fuse/relay box
Trunk/Hatch Release      YELLOW /GREEN      +      trunk lid opener switch, blue 5 pin plug, pin 2
Power Sliding Door      N/A
Factory Alarm Arm      WHITE/ red (driver door key cylinder)      -      power window master switch, green 22 pin plug, pin 19
Factory Alarm Disarm      white (driver door key cylinder)      -      power window master switch, green 22 pin plug, pin 18
Disarm No Unlock      see factory alarm disarm
Tachometer      brown, red, blue, yellow, BLACK/ red, or WHITE/ blue      ac      any fuel injector, black 2 pin plug, pin 2 or gray 2 pin plug, pin 1
Wait to start      N/A
Brake Wire      WHITE/ black      +      dash fuse box, white 45 pin plug, pin 26
Parking Brake      GREEN/ orange      -      dash fuse box, white 45 pin plug, pin 30
Horn Trigger      GREEN/ YELLOW      -      left of steering column, brown 22 pin plug, pin 19
Memory Seat 1      blue / YELLOW      -      power window master switch, green 22 pin plug, pin 4
Memory Seat 2      RED / yellow      -      power window master switch, green 22 pin plug, pin 3
Memory Seat 3      N/A      -
Interface Modules: Not Available
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
bwright2112
Posted: November 12, 2012 at 10:32 AM / IP Logged
Awesome thanks man!
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
