carvox 2300 x6a domelight problems :
randyhub
Copper - Posts: 51
Posted: December 16, 2012 at 12:16 PM / IP Logged
Agreed, he charged $250.00 for the install and is a good guy (my friends use him for all kinds of installs) by I checked he soldered everything and used split loom so I am happy. I was just worried about the remote starter wiring as I have installed lots of alarm systems, brake controllers and such.
I just did not like where he installed the status led, valet switch, shock sensor, or antennas. My buddies did comment most people would not have been able to fix a few of these issues and reprogram the brain as many now use a much simplier PC interface.
Oh well will be doing some wiring this Christmas as I am a bit of stickler when it comes to installation work I never use crimps, I prefer shrink wrap, liquid tape, and split loom.
Randy
Posted: December 16, 2012 at 12:31 PM / IP Logged
Heat shrink, or to be anal adhesive lined for under the hood.
Scotch 33+ for non-butt joints.
On Euro cars I use fabric looming tape, matches up with the factory loom for stealth. $7.50 per roll!
I only use crimp connectors (with a compound ratchet crimper) as ring terminals and fully insulated fastons for pin switches, even then I use 6.4 (1/4") heat shrink over the crimp connectors under the hood AND spray the pin switch and the rear of the siren with moisture retardant.
I won't use split corrugated looming on customer's cars under the hood because they won't pay for it.
Who makes the liquid tape? I need to get some.
I even have a collection of Molex Sure-seal IP65 connectors, but who's going to pay for that?
Posted: December 16, 2012 at 12:35 PM / IP Logged
Don't worry, Googled it and found it on Amazon.
randyhub
Copper - Posts: 51
Posted: December 16, 2012 at 12:54 PM / IP Logged
If I need to use a connector I like the T connectors. I like the liquid tape when I just need to slice into a wire and it is a bit tight to get full wraps of tape and just need something like rubber to cover a shiner (exposed copper).
Randy
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
