viper 350 plus silverado
jaimejr18
Member - Posts: 26
Posted: February 24, 2013 at 6:47 PM / IP Logged
i have a 2003 chevy silverado 1500 and im trying to install a viper 350 plus alarm if anyone can help me or post a wiring schematic of wich wire goes were itd be appreciated
itsyuk
Silver - Posts: 505
Posted: February 25, 2013 at 11:58 PM / IP Logged
start here first
http://www.bulldogsecurity.com/bdnew/vehiclewiringdiagrams.asp
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
offroadzj
Gold - Posts: 2,043
Posted: February 26, 2013 at 6:01 AM / IP Logged
If you can, post up the wire connections from the Viper install manual. That will at least give us a head start to help you link the 2 diagrams together. A lot of us tend to be busy and as much as we love to help, we don't always have time to search for the manual and then make up a complete write-up for wire to wire connections. But if you can get us at least half way there, it will save us time.
Use this format:
Connector 1:
Pin (if available) - Wire Color - Wire description (ie ignition, status out, etc)
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted: February 26, 2013 at 6:54 AM / IP Logged
Nice one Kenny.
Think I'll copy and paste your post as a template. Like I do with Kregg's version, you'll get a copyright credit.
offroadzj
Gold - Posts: 2,043
Posted: February 26, 2013 at 9:06 AM / IP Logged
ALso, which bypass are you using?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
offroadzj
Gold - Posts: 2,043
Posted: February 26, 2013 at 9:07 AM / IP Logged
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted: February 26, 2013 at 9:29 AM / IP Logged
It's NOT an R/S Kenny, just an entry level alarm with the 1st. generation 2 way.
offroadzj
Gold - Posts: 2,043
Posted: February 28, 2013 at 5:59 AM / IP Logged
Testing this out...
Vehicle: 2003 Chevy Silverado
Alarm / Remote Start Unit: Viper 350 Plus
Bypass Module:
Alarm / Remote Start / Bypass Unit   Vehicle
Connection     Color     Description     Color     Polarity     Location:
H1     RED / White     Trunk release     No connection
     Red      12v Constant Power input     Red (40amp)     +     Ignition harness
     Brown     Siren Output     Connect to red wire on alarm siren
     Yellow     Switched Ignition Input     Pink     +     Ignition harness
     Black     Chassis Ground     Connect to solid chassis ground.
     Violet     (+) door trigger input     No connection
     Blue     (-) Instant trigger input     Optional hood pin or external trigger.
     Green     (-) Door trigger input     gray / black     -     driver window switch (pin 18; black 26 pin plug)
     ** On base models, it is gray / black (-) at the BCM pin B4; Light blue plug. The BCM is under the driver dash.
     Black / White     (-) 200mA Domelight supervision     Optional connection. Not required.
     White / Blue     (-) 200mA Channel 3 programmable output     Optional connection. Not required.
     White      (+/-) Selectable light flash output     gray / black     -     BCM pin B2; brown plug
     ** Change Viper's light flash jumper to (-) output.
     Orange     (-) 500mA Ground when armed output     Optional connection. Not required.
Lock Harness     Blue     (-) unlock / (+) lock output     Must use interface module for locks or refer to Tech Doc 1601
     Green     (-) lock / (+) unlock output     Must use interface module for locks or refer to Tech Doc 1601
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
jaimejr18
Member - Posts: 26
Posted: February 28, 2013 at 9:02 AM / IP Logged
ive been working out of town for the last few days yesterday i got home n wired it up with no problems thank yall for the help today when i get home or tommorow ill post pictures
jaimejr18
Member - Posts: 26
Posted: February 28, 2013 at 9:04 AM / IP Logged
the only problem im having is connectin the proximity sensor to the alarm i cant figure it out    i dunno if suppose to start a new thread or if its ok for me to write this on here
Page of 5
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
