battery drain
blake292
Posted: March 25, 2013 at 6:10 PM / IP Logged
I just installed an Avital 4103 RS and XK01 Bypass into my 2004 Buick Park Avenue. I used W2W and soldered all connections. Before the install, the parasitic battery drain measured 30 milliamps. After installing, I'm seeing 60 milliamps.
Is this increased draw typical, or should I look for a problem with my installation?
Thanks.
KPierson
Platinum - Posts: 3,527
Posted: March 25, 2013 at 8:19 PM / IP Logged
Are you having an issue with the vehicle? I don't like to see above 50mA with everything off, but I wouldn't be overly concerned about 60mA.
Kevin Pierson
Posted: March 26, 2013 at 3:32 AM / IP Logged
Surely that extra 30mA is within limits?
blake292
Posted: March 26, 2013 at 3:32 PM / IP Logged
Thanks for the responses. There doesn't seem to be any problems and everything works as expected. I was just a little surprised at the 30mA increase. I have always thought that anything over 50mA total may be excessive, but I guess I'm close enough not to worry.
Out of curiosity, is the bypass module suppose to always be on? Or does it shut down when not needed, and what triggers it?
dare_ds69
Silver - Posts: 419
Posted: April 02, 2013 at 12:52 PM / IP Logged
bypass need 12v constant however, is triger by the R/S, it should work only when is need it
how own your mind, control your life.
MECP certified. always use a DMM
Moderator - Posts: 12,488
Posted: April 03, 2013 at 11:48 AM / IP Logged
Most draws that I've seen have been because of high resistance on the ground location for the RS/Security system. Test the ground that you have by referencing it to the battery terminal ( not where the battery ground is attached to in the engine compartment ). I've seen resistances as high as 21 ohms on Ford's on the ground reference. Ford's are terrible for grounds and therefore terrible for parasitic draws.
Monday, May 6, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
