2013 Jeep Grand Cherokee Laredo Alarm/RS/Stereo Wiring
ateebull
Posted: May 13, 2013 at 9:25 PM / IP Logged
I need the wiring diagram for 2013 Jeep Grand Cherokee Laredo, if anyone could help me out I will be really thankful. Im installing a remote start.
AteeBull
tonanzith
Gold - Posts: 601
Posted: May 13, 2013 at 9:43 PM / IP Logged
You WILL need a bypass module.
12 Volts     red     +     battery or TIPM on passenger fender
Second 12 Volts     lt. blue/red (10A)     +     Wireless Ign Node on ign sw, blk 12 pin plg, pin 1
Starter     yellow/gray (for starter kill only)     +     starter or TIPM on passenger fender, blu 26 pin plug (C2), pin 8
Second Starter     N/A
Ignition     pink/white (for ignition sense only)     +     Wireless Ignition Node on ignition switch, black 12 pin plug, pin 3
Second Ignition     N/A
Third Ignition     N/A
Accessory     N/A
Second Accessory     N/A
Third Accessory     N/A
Keysense     N/A
Data Bus     N/A
Can Bus High     WHITE/ lt. blue (CAN C bus)     data     Wireless Ignition Node on ignition switch, black 12 pin plug, pin 5
The CAN IHS bus high is WHITE/ gray in the driver kick, door harness.
Can Bus Low     WHITE/ brown (CAN C bus)     data     Wireless Ignition Node on ignition switch, black 12 pin plug, pin 6
The CAN IHS bus low is WHITE/ orange in the driver kick, door harness.
Can Bus Sw     N/A
Power Lock     PURPLE / lt. green (passenger door lock switch)     - 330 ohms     Passenger Door Module, black 10 pin plug, pin 4
Power Unlock     same as power lock     - 100 ohms
Lock Motor     tan/white     5 wire     driver kick, door harness
Driver Unlock Motor     tan/lt. green     5 wire     driver kick, door harness
Passenger Unlock Motor     tan/orange     5 wire     driver rear door harness
Parking Lights (-)     WHITE/ lt. green (need to relay isolate the switch)     -1130 ohms     headlight switch, black 10 pin plug, pin 1
Parking Lights (+)     WHITE/ brown (L), WHITE/ orange (R)     +     driver kick, harness to rear
Hazards     WHITE/ dk. blue     -     hazard switch, black 12 pin plug, pin 4
Turn Signal (Left)     WHITE/ lt. green (F); white (R)     +     TIPM on pass fender, gry 16P plug(C4), pin 9; blk 50P plg(C7), pin 49
Turn Signal (Right)     WHITE/ tan (F); WHITE/ yellow (R)     +     TIPM on pass fender, gry 16P plug(C4), pin 7; blk 50P plg(C7), pin 50
Headlight     WHITE/ lt. green (need to relay isolate the switch)     - 660 ohms     headlight switch, black 10 pin plug, pin 1
AutoLights     WHITE/ lt. green (need to relay isolate the switch)     -2Kohm(off     headlight switch, black 10 pin plug, pin 1
Reverse Light     WHITE/ lt. green     +     driver kick, harness to rear
Left Front Door Trigger     purple     -     driver kick, door harness
Right Front Door Trigger     PURPLE / white     -     passenger kick, door harness
Left Rear Door Trigger     PURPLE / gray     -     driver kick, harness to rear
Right Rear Door Trigger     purple / YELLOW     -     passenger kick, harness to rear
Dome Supervision     yellow/white     +     driver kick, harness to rear
Trunk/Hatch Pin     PURPLE / orange     -     passenger kick, harness to rear
Rear Glass Pin     purple / YELLOW     -     driver kick, harness to rear
Hood Pin     PURPLE / lt. blue     -     hood switch or TIPM on passenger fender, gry 16 pin plug (C4), pin 3
Trunk/Hatch Release     purple (liftgate glass)     -     driver kick, harness to rear
The power liftgate open/close is PURPLE / tan (- 4700 ohms) at the overhead console assembly, black 16 pin plug, pin 15.
Trunk Release Motor     ORANGE / gray (liftgate glass)     5 wire     driver kick, harness to rear
Fuel Door Release     lt. GREEN/ orange     +     fuel door switch, black 2 pin plug, pin 2
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with door open
Factory Alarm Disarm     see disarm no unlock
Disarm No Unlock     Sentry Key and ignition
Trunk Alarm Shunt     N/A
Tachometer     NOT BROWN / white     ac     any fuel injector
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     N/A
Fuel Pump     dk. blue/orange     +     driver kick, harness to rear
Rear Defroster     dk. blue/white     + latched     driver kick, harness to rear
Mirror Defroster     (CAN IHS bus)
Left Front Heated Seat     (CAN IHS bus)
Right Front Heated Seat     (CAN IHS bus)
Speed Sense     dk. GREEN/ brown (some models only)     ac     Powertrain Ctrl Mod on front of TIPM, blk/grn 38 pin plug, pin 32
Brake Wire     WHITE/ dk. green     +     brake switch or Wireless Ign Node on ign sw, black 12 pin plug, pin 8
Parking Brake     dk. GREEN / WHITE     -     parking brake switch, black 1 pin plug, pin 1
Horn Trigger     gray / YELLOW (1), gray/lt. blue (2)     +     horns or TIPM on pass fender, grn 26 pin plug (C3), pins 18 and 24
Wipers     BROWN / white (L), BROWN / orange (H)     +     wpr mtr or TIPM on pass fndr, brn 40 pin plug (C5), pins 12 and 11
Left Front Window (Up/Down)     ORANGE / lt. green - ORANGE / black     A     Driver Door Module, purple 5 pin plug, pins 4 and 5
Right Front Window (Up/Down)     ORANGE / brown - ORANGE / purple     A     Passenger Door Module, purple 5 pin plug, pins 4 and 5
Left Rear Window (Up/Down)     tan / YELLOW - tan/lt. blue     A     left rear power window switch, lt. gray 6 pin plug, pins 2 and 3
Right Rear Window (Up/Down)     ORANGE / brown - ORANGE / purple     A     right rear power window switch, lt. gray 6 pin plug, pins 2 and 3
Sun Roof (Open/Close)     ORANGE / tan - ORANGE / lt. blue (funct w/ign on only)     -     overhead console assembly, black 16 pin plug, pins 9 and 11
Sun Roof (Limit/Close)     N/A
Memory Seat 1     PURPLE / brown     - resistor     Driver Door Module, black 10 pin plug, pin 6
Memory Seat 2     same as memory seat 1     - resistor
Memory Seat 3     N/A
Radio 12V     yellow/red     +     radio, gray 22 pin plug, pin 1
Radio Ground     black     -     radio, gray 22 pin plug, pin 12
Radio Ignition     (CAN IHS bus)
Radio Illumination     (CAN IHS bus)
Factory Amp Turn-on     (CAN IHS bus)
Power Antenna     gray/orange     +     radio, gray 22 pin plug, pin 7
Left Front Speaker (+/-)     gray/purple - gray / YELLOW     +,-     radio, gray 22 pin plug, pins 21 and 22
On models with amplifier, the speaker wires are gray/purple - gray / YELLOW at the amplifier in LR quarter panel, black 16 pin plug, pins 8 and 16. The tweeter wires are gray/orange - gray / YELLOW at the amplifier, white 22 pin plug, pins 20 and 9.
Right Front Speaker (+/-)     dk. GREEN/ purple - dk. GREEN/ YELLOW     +,-     radio, gray 22 pin plug, pins 19 and 20
On models with amplifier, the speaker wires are dk. GREEN/ purple - dk. GREEN/ YELLOW at the amplifier in LR quarter panel, black 16 pin plug, pins 7 and 15. The tweeter wires are gray/dk. green - gray/lt. green at the amplifier, white 22 pin plug, pins 19 and 8.
Left Rear Speaker (+/-)     dk. GREEN/ dk. blue - dk. GREEN/ orange     +,-     radio, gray 22 pin plug, pins 8 and 9
On models with amplifier, the speaker wires are gray/lt. green - gray/dk. green at the amplifier in LR quarter panel, black 16 pin plug, pins 13 and 5. The surround wires are dk. GREEN/ tan - dk. GREEN/ gray at the amplifier, white 22 pin plug, pins 10 and 21.
Right Rear Speaker (+/-)     gray/dk. blue - gray/orange     +,-     radio, gray 22 pin plug, pins 10 and 11
On models with amplifier, the speaker wires are dk. GREEN/ lt. green - dk. GREEN/ gray at the amplifier in LR quarter panel, black 16 pin plug, pins 4 and 12. The surround wires are dk. GREEN/ brown - yellow/gray at the amplifier, black 16 pin plug, pins 10 and 2.
Center Channel (+/-)     gray/brown - gray/orange     +,-     amplifier in LR quarter panel, white 22 pin plug, pins 11 and 22
Subwoofer (+/-)     gry/brn - dk grn/brn (1); gry/wht - dk grn/wht (2)     +,-     amplifier in LR quarter panel, blk 16 pin plug, pins 3 - 11; 14 - 6
Aux. Audio Input Left (+/-)     dk. GREEN/ orange - dk. green (handsfree audio)     +,-     radio, gray 10 pin plug, pins 1 and 6
Aux. Audio Input Right (+/-)     dk. GREEN/ YELLOW - dk. green (handsfree audio)     +,-     radio, gray 10 pin plug, pins 2 and 6
RSE Video (+/-)     gray/brn - gray/yel (1); gry/lt. blu - gry/yel (2)     +,-     radio, white 22 pin plug, pins 6 and 7; 9 and 10
The rearview camera video wires are dk. GREEN/ brown - dk. GREEN/ orange at the radio, white 22 pin plug, pins 3 and 4.
RSE Audio Left (+/-)     see notes
Audio 1: dk. GREEN/ tan (left), dk. GREEN / WHITE (right), gray/purple (common) at radio, white 22 pin plug, pins 18, 20, and 19. Audio 2: dk. GREEN/ lt. blue (left), dk. GREEN/ dk. blue (right), gray/orange (common) at radio, white 22 pin plug, pins 21, 22, and 12. Audio 3: dk. GREEN/ purple (left), dk. GREEN/ YELLOW (right), gray/lt. blue (common) at radio, white 22 pin plug, pins 13, 14, and 1.
RSE Audio Right (+/-)     see RSE audio left
Satellite Radio 12 Volts     N/A
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Item     Size     Depth     Location
Headunit     double DIN center of dash
Left Front Speaker     6 x 9 left front door
Left Front Tweeter     1 left front door
Right Front Speaker     6 x 9 right front door
Right Front Tweeter     1 right front door
Left Rear Speaker     6.5 left rear door
Left Rear Tweeter     2.5 left rear pillar
Right Rear Speaker     6.5 right rear door
Right Rear Tweeter     2.5 right rear pillar
Center Channel     3.5 top center of dash
Subwoofer     8 right rear quarter panel
Left Front Headrest
Right Front Headrest
Gary Sather
Tuesday, June 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
