2004 Pontiac GTO Remote Start
pbmgto
Member - Posts: 12
Posted: June 02, 2013 at 2:20 PM / IP Logged Link to Post Post Reply Quote pbmgto
Yes but it has been a while. I can do it again. Can you remind me what the sequence is?
Posted: June 02, 2013 at 2:34 PM / IP Logged Link to Post Post Reply Quote howie ll
Start engine, within 5 seconds press and hold button on control centre, blue light should come on, release button, tach learnt.
pbmgto
Member - Posts: 12
Posted: June 02, 2013 at 3:17 PM / IP Logged Link to Post Post Reply Quote pbmgto
I relearned tach. Still the same issue.
racerjames76
Silver - Posts: 581
Posted: June 04, 2013 at 8:19 AM / IP Logged Link to Post Post Reply Quote racerjames76
Just curious, where is your door trigger hooked to? Or is that not required on this unit?
To master and control electricity is perfection. *evil laugh*
Posted: June 04, 2013 at 9:50 AM / IP Logged Link to Post Post Reply Quote howie ll
RJ, I made an assumption and forgot mention it, yes door switch is required, whether installed or not I assumed it was. Ooops.
pbmgto
Member - Posts: 12
Posted: June 10, 2013 at 6:48 PM / IP Logged Link to Post Post Reply Quote pbmgto
Door trigger is connected to grey/white and white at the BCM and diode isolated. Door triggers work just fine.
offroadzj
Gold - Posts: 2,043
Posted: June 10, 2013 at 9:27 PM / IP Logged Link to Post Post Reply Quote offroadzj
How do you have the hood pin and factory alarm arm/disarm wires connected? Do any of them tie into the door pin connections?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
racerjames76
Silver - Posts: 581
Posted: June 12, 2013 at 8:39 AM / IP Logged Link to Post Post Reply Quote racerjames76
If you havent gathered what we are asking is, we think there may be an issue with something the brain is looking for during the setup sequence. go through the process of what it wants and check to make sure the remote brain is getting the correct inputs at the correct time. 2004 Pontiac GTO Remote Start - Page 2 -- posted image.
pbmgto
Member - Posts: 12
Posted: July 18, 2013 at 10:38 AM / IP Logged Link to Post Post Reply Quote pbmgto
What inputs are you talking about? Foot brake, parking brake, and door pin are the only things I can think it would need and those all work.
pbmgto
Member - Posts: 12
Posted: July 18, 2013 at 10:39 AM / IP Logged Link to Post Post Reply Quote pbmgto
Factory arm/disarm is only from factory remote and I disconnected the hood pin because another GTO owner said he had problems with his.
Page of 3
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
