2008 Dodge Caliber, Alarm/RS, Stereo Wiring
fosgate24360
Copper - Posts: 104
Posted: June 04, 2013 at 8:45 PM / IP Logged Link to Post Post Reply Quote fosgate24360
hey all, just wondering if anyone out there has the wire color codes for a 2008 dodge caliber se(basic model/no power)? it has just the basic standard 4 speaker system and not the higher end amplified. basically wanting the stereo install info....I see in the search it only shows up to 2007 caliber, maybe its all the same. I put a after market stereo in with just a basic wire harness and it wont shut off with the ignition, just stays on until I pop the faceplate or manually push the power button. im thinking maybe this has the can-bus system. I know it had the rap feature with the factory radio and stayed on until a door was opened. if I need a special adapter, anyone know what it would be? thanks in advance for the help.
tonanzith
Gold - Posts: 593
Posted: June 05, 2013 at 9:29 PM / IP Logged Link to Post Post Reply Quote tonanzith
You may need a module.
C2a-chy or another. Here is a link.
http://www.pac-audio.com/productSearch.aspx?Make=Dodge&MakeId=7&Model=Caliber&ModelId=1351&Year=2008&YearId=19
12 Volts     red     +     battery or TIPM
The TIPM (Totally Integrated Power Module) is in the engine compartment, on the driver fender.
Second 12 Volts     RED / orange (10A)     +     ignition switch, black 5 pin plug, pin 5
Starter     yellow/gray (for starter kill only)     +     driver fender, 8 pin plug, pin 6
Second Starter     PURPLE / brown     - 180 ohms     ignition switch, black 5 pin plug, pin 2
If interface module is not available, see Tech Doc 1084 for wiring information.
Ignition     pink/white     +     ignition switch, black 5 pin plug, pin 3
Second Ignition     N/A
Third Ignition     N/A
Accessory     same as second starter     - 610 ohms
Second Accessory     N/A
Third Accessory     N/A
Keysense     same as second starter     -8.5K ohms
Data Bus     N/A
Can Bus High     WHITE/ orange (CAN B BUS)     data     SKREEM, black 8 pin plug, pin 6
The SKREEM (Sentry Key Remote Entry Module) is around the ignition switch.
Can Bus Low     WHITE/ pink (CAN B BUS)     data     SKREEM, black 8 pin plug, pin 7
Can Bus Sw     N/A
Power Lock     lt. GREEN/ dk. green     - 330 ohms     left of steering column, black 43 pin plug, pin 30
Power Unlock     same as power lock     - 100 ohms
Lock Motor     tan/dk. blue     5 wire     left of steering column, black 43 pin plug, pin 11
Driver Unlock Motor     tan/dk. green     5 wire     left of steering column, black 43 pin plug, pin 39
Passenger Unlock Motor     tan/white     5 wire     left of steering column, black 43 pin plug, pin 12
Parking Lights (-)     (LIN BUS)
Parking Lights (+)     WHITE/ purple     +     driver kick, harness to rear
Hazards     (LIN BUS)
Turn Signal (Left)     WHITE/ red (F), dk. GREEN/ red (R)     +     turn signal light (F); driver kick, harness to rear (R)
Turn Signal (Right)     WHITE/ tan (F), WHITE/ yellow (R)     +     turn signal light (F); passenger kick, harness to rear (R)
Headlight     WHITE/ dk. blue (L), PURPLE / red (R)     +     headlights, green 3 pin plug, pin 1
AutoLights     N/A
Reverse Light     WHITE/ lt. green     +     driver kick, harness to rear
Left Front Door Trigger     PURPLE / dk. blue     -     left of steering column, black 43 pin plug, pin 17
Right Front Door Trigger     PURPLE / white     -     left of steering column, black 43 pin plug, pin 15
Left Rear Door Trigger     PURPLE / gray     -     left of steering column, black 43 pin plug, pin 24
Right Rear Door Trigger     purple / YELLOW     -     left of steering column, black 43 pin plug, pin 23
Dome Supervision     yellow/white     +     driver A pillar
Trunk/Hatch Pin     PURPLE / orange     -     left of steering column, black 43 pin plug, pin 1
Rear Glass Pin     N/A
Hood Pin     PURPLE / lt. blue     -     hood switch, black 2 pin plug, pin 1
Trunk/Hatch Release     N/A
Trunk Release Motor     N/A
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     arms on lock with door open
Factory Alarm Disarm     see disarm no unlock
Disarm No Unlock     Sentry Key, ignition, and keysense
Trunk Alarm Shunt     N/A
Tachometer     yellow/brn, brn/dk. blue, brn/lt. blue, or brn/tan     ac     any fuel injector, black 2 pin plug, pin 1
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     BLACK / YELLOW (input), yellow/red (output)     - N.O.     clutch switch, black 3 pin plug, pins 2 and 3
Fuel Pump     dk. blue/orange     +     driver kick, harness to rear
Rear Defroster     lt. blue/orange     5 wire     driver kick, harness to rear
Mirror Defroster     dk. blue/gray     5 wire     driver kick, door harness
Left Front Heated Seat     lt. GREEN/ brown     5 wire     Heated Seats Module, black 10 pin plug, pin 4
The Heated Seats Module is under the driver seat.
Right Front Heated Seat     lt. GREEN/ purple     5 wire     Heated Seats Module, black 10 pin plug, pin 10
Speed Sense     dk. blue/orange (M/T)     ac     PCM, 58 pin plug, pin 38 (M/T)
The PCM (Powertrain Control Module) is in the engine compartment, by the driver side strut tower. On automatic transmission vehicles, the VSS wire is dk. GREEN / WHITE at the Transmission Control Module under the driver dash, lt. gray 24 pin plug, pin 5.
Brake Wire     dk. GREEN / WHITE     +     left of steering column, black 43 pin plug, pin 27
Parking Brake     dk. GREEN / WHITE     -     parking brake switch
Horn Trigger     dk. GREEN/ purple     -     horn switch, white 6 pin plug, pin 3
Wipers     BROWN / white (L), BROWN / lt. blue (H)     +     wiper motor, lt. gray 5 pin plug, pins 1 and 4
Left Front Window (Up/Down)     ORANGE / lt. green - ORANGE / white     A     driver power window switch, lt. gray 8 pin plug, pins 7 and 6
Right Front Window (Up/Down)     ORANGE / tan - ORANGE / gray     A     driver kick, door harness
Left Rear Window (Up/Down)     ORANGE / white - ORANGE / gray     A     driver kick, door harness
Right Rear Window (Up/Down)     ORANGE / lt. blue - ORANGE / dk. blue     A     driver kick, door harness
Sun Roof (Open/Close)     org/tan - org/lt. blue (function with ign on only)     +     sunroof switch, black 4 pin plug, pins C and D
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     RED / lt. blue     +     radio, gray 22 pin plug, pins 1 and 12
Radio Ground     BLACK / YELLOW     -     radio, gray 22 pin plug, pins 11 and 22
Radio Ignition     (CAN B BUS)
Radio Illumination     (CAN B BUS)
Factory Amp Turn-on     (CAN B BUS)
Power Antenna     gray/red     +     radio, gray 22 pin plug, pin 13
Left Front Speaker (+/-)     gray/purple - gray / YELLOW     +,-     radio, gray 22 pin plug, pins 10 and 9
If equipped, the amplifier is in the right side of the cargo area. On vehicles with amplifier, the door speaker wires are dk. GREEN/ purple - dk. GREEN/ black at the amplifier, white 14 pin plug, pins 1 and 7. The dash speaker wires are gray/tan - gray/brown at the amplifier, white 20 pin plug, pins 1 and 10.
Right Front Speaker (+/-)     dk. GREEN/ purple - dk. GREEN/ YELLOW     +,-     radio, gray 22 pin plug, pins 7 and 8
If equipped, the amplifier is in the right side of the cargo area. On vehicles with amplifier, the door speaker wires are gray/lt. blue - gray / YELLOW at the amplifier, white 14 pin plug, pins 8 and 2. The dash speaker wires are gray/dk. green - gray/lt. green at the amplifier, white 20 pin plug, pins 2 and 11.
Left Rear Speaker (+/-)     dk. GREEN/ dk. blue - dk. GREEN/ brown     +,-     radio, gray 22 pin plug, pins 18 and 19
If equipped, the amplifier is in the right side of the cargo area. On vehicles with amplifier, the door speaker wires are gray/lt. green - gray/dk. green at the amplifier, white 14 pin plug, pins 3 and 9. The liftgate speaker wires are dk. GREEN/ dk. blue - dk. GREEN/ tan at the amplifier, white 14 pin plug, pins 5 and 13.
Right Rear Speaker (+/-)     gray/dk. blue - gray/orange     +,-     radio, gray 22 pin plug, pins 21 and 20
If equipped, the amplifier is in the right side of the cargo area. On vehicles with amplifier, the door speaker wires are dk. GREEN/ lt. green - dk. GREEN/ lt. blue at the amplifier, white 14 pin plug, pins 4 and 12. The liftgate speaker wires are gray/dk. blue - gray/tan at the amplifier, white 14 pin plug, pins 6 and 14.
Center Channel (+/-)     N/A
Subwoofer (+/-)     same as rear speakers
Aux. Audio Input Left (+/-)     N/A
Aux. Audio Input Right (+/-)     N/A
RSE Video (+/-)     N/A
RSE Audio Left (+/-)     N/A
RSE Audio Right (+/-)     N/A
Satellite Radio 12 Volts     red     +     Satellite Receiver, black 12 pin plug, pin 6
If equipped, the Satellite Receiver is in the left side of the cargo area.
Satellite Radio Ground     black     -     Satellite Receiver, black 12 pin plug, pin 4
Satellite Radio Ignition     (CAN BUS)
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     dk. GREEN/ orange - dk. green     +,-     Satellite Receiver, black 12 pin plug, pins 1, 8
Satellite Audio Right (+/-)     dk. GREEN/ YELLOW - dk. green     +,-     Satellite Receiver, black 12 pin plug, pins 7, 8
Item     Size     Depth     Location
Headunit     double DIN center of dash
Left Front Speaker     6 x 9     4     left front door
Left Front Tweeter     2.5     2     left front dash
Right Front Speaker     6 x 9     4     right front door
Right Front Tweeter     2.5     2     right front dash
Left Rear Speaker     6 x 9     4     left rear door
Left Rear Tweeter     3.5     2.5     left rear liftgate
Right Rear Speaker     6 x 9     4     right rear door
Right Rear Tweeter     3.5     2.5     right rear liftgate
Center Channel     N/A
Subwoofer     8     6     right rear quarter panel
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner   left side of cargo area
Gary Sather
murdock73
Posted: October 02, 2016 at 12:07 AM / IP Logged Link to Post Post Reply Quote murdock73
Hi
I am in New Zealand and Have a 2011 Caliber- it appears the colour codes are the same as 08 and I am trying to install a reversing camera. Where can I locate the reverse lamp wire, when you say drivers Kickspace can you please explain and is this reversed for RHD vehicle.
Sorry for daft question but I really dont want to run a l\cable all the way from reverse light to console to trigger the screen.
Cheers
Mike
Mike H
geepherder
Platinum - Posts: 3,668
Posted: October 02, 2016 at 8:53 PM / IP Logged Link to Post Post Reply Quote geepherder
The kick panel is the panel just in front of the door between the carpet and the dashboard.
