how to wire an actuator?
Ween
Platinum - Posts: 1,366
Posted: November 28, 2013 at 9:23 PM / IP Logged
if the actuator has more than enough strength to unlatch the latch, you can try adding a return spring to pull the actuator back to the at-rest position. you'd need to use a relay to drive the actuator. use relay to convert negative output to a positive, ground other lead of actuator. also if the trunk is too heavy it may relatch after power is removed.
mark
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
