ads blade al for 05 jetta windows?
howie (aka: harryharris)
Silver - Posts: 355
Posted: February 18, 2014 at 4:17 AM / IP Logged
In that instance can't you program comfort close on the DB-ALL to raise the windows?
Test before boxing up.
cdx280
Member - Posts: 10
Posted: February 18, 2014 at 8:09 AM / IP Logged
Have you tried locking the doors first before triggering the aux output for windows up?
freqsounds
Copper - Posts: 289
Posted: February 18, 2014 at 8:11 AM / IP Logged
I have not tried that, but I will! I know these cars can be very temperamental.
No question is stupid or not worth asking. You were once a noob, right? :)
freqsounds
Copper - Posts: 289
Posted: February 18, 2014 at 8:13 AM / IP Logged
I could, but doesn't the Comfort Closure just fire the AUX channel? I haven't done anything with Comfort Closure before, so I'm not 100% sure, but it would make sense if if just fires the AUX automatically.
Silver - Posts: 355
Posted: February 18, 2014 at 8:32 AM / IP Logged
First comfort closure replaces the 0.4 or 0.8 lock outputs with a 20 second timed output.
Nothing to do with the aux outputs.
Secondly programming of the alarm and or R/S isn't needed for these functions, all done by the DB-ALL.
Thirdly have you looked at page 20 of the DB-ALL instructions.
freqsounds
Copper - Posts: 289
Posted: February 18, 2014 at 8:39 AM / IP Logged
Alright, that makes sense. I've never programmed the comfort closure before (never had a reason to mess with it).
I will try to enable the comfort closure and see what happens. If this is programmed, will comfort closure roll up the windows any time the doors are locked? If so, the customer is going to throw a fit lol, he's one of those guys... ads blade al for 05 jetta windows? - Page 2 -- posted image.
Silver - Posts: 355
Or from your unit take the 2 aux wires and relay each to increase the current, unlock with a 259R resistor, neg to neg then to a GREEN / WHITE in the factory door module this will give you window close/open without affecting the DB-ALL.
Silver - Posts: 355
Posted: February 18, 2014 at 8:43 AM / IP Logged
I've always done them that way when using a DB-ALL, what I mean is ignore my last post I would have assumed you'd have read the instructions on page 20.
Using comfort close automatically closes windows and roof when present, using an aux means more button pressing to achieve it.
Silver - Posts: 355
Sorry, can't edit, what I should have written is more button pressing and linking it to arm.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
