First your going to need a bypass kit from bypasskits.com. These trucks have a data bus and without it you will need to relay evrey door. You can also get your passlock bypass from there too. Basicly you just wire it following the instructions included, after you wire it in just start your truck with the key and that all you have to do. Now about the diesel. If you don't need to wait for the glow plugs to warm up your fine. Just find a good tach and wire your tach wire to it.
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red (x2) |+ |ignition harness |
| STARTER|yellow |+ |ignition harness |
| IGNITION|pink (12 awg) |+ |ignition harness |
| SECOND IGNITION|white |+ |ignition harness |
| ACCESSORY|orange |+ |ignition harness |
| SECOND ACCESSORY|brown |+ |ignition harness |
| POWER LOCK|use Directed module | | |
| POWER UNLOCK|part #456G *2 | | |
| LOCK MOTOR|gray | |driver door module in door |
| UNLOCK MOTOR|tan | |driver door module in door |
| DISARM DEFEAT|tan | |pass. door module in door |
| PARKING LIGHTS +| | | |
| PARKING LIGHTS -|gray/black | |brown plug @ BCM *1 |
| HEADLIGHTS| | | |
| DOOR TRIGGER|gry/blk(L),blk/wht(R|- |each door module in door *3 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN| | | |
| HOOD PIN| | | |
|TRNK/HTCH RELEASE| | | |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|lt. green |- |driver door module in door |
| TACHOMETER|NOT pnk, blk, or brn| |any ignition coil |
| SPEED SENSE| | | |
| BRAKE WIRE|white |+ |brake pedal switch |
| HORN TRIGGER|black |- |steering column |
| WIPERS|pink |- |steering column |
| LF WINDOW UP/DN|blue - brown |A |driver window motor |
| RF WINDOW UP/DN|blue - brown |A |passenger window motor |
| LR WINDOW UP/DN| | | |
| RR WINDOW UP/DN| | | |
| SUN RF OPN/CLOSE| | | |
| SUN ROOF LIMIT| | | |
| RADIO 12V| | | |
| RADIO GROUND| | | |
| RADIO SWITCH| | | |
| RADIO ILLUMINATE| | | |
| POWER ANTENNA| | | |
| LF SPEAKER| | | |
| RF SPEAKER| | | |
| LR SPEAKER| | | |
| RR SPEAKER| | | |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. The passlock II wire colors are yellow, black, and RED / white (not used). *1 The BCM (Body Control Module) is under the driver side dash. *2 If Directed module part #456G is not available, refer to directfax document #1601. On base model trucks the lock wire is lt. blue (-) and unlock wire is white (-). They are in the lt. blue plug at the BCM. *3 On base model trucks the door trigger wires are in the lt. blue plug at the BCM. On 4dr trucks the LR door trigger is lt. blue/black, and the RR is lt. GREEN/ black. They are in the purple plug at the BCM. Use all wires and diode isolate.
