2012 Ford Taurus SEL Alarm/Remote Start Wiring
jtur6879
Posted: February 24, 2014 at 4:26 PM / IP Logged
Hello, I'm looking for Remote Start Wiring for the 2012 Ford Taurus sel.
Many Thanks ..in advance.
wirewise
Moderator - Posts: 489
Posted: February 24, 2014 at 4:52 PM / IP Logged
FORD / TAURUS / 2012 / Remote Start
12volts      blue/red (20A)      +      ignition switch, black 7 pin plug, pin 4
Notes: The SJB (Smart Junction Box) is the fuse box, under the driver dash.
Starter      blue/white      +      ignition switch, black 7 pin plug, pin 7
Second Starter      N/A
Ignition      GREEN/ purple      +      ignition switch, black 7 pin plug, pin 1
Second Ignition      N/A
Third Ignition      N/A
Accessory      PURPLE / green      +      ignition switch, black 7 pin plug, pin 6
Second Accessory      N/A
Keysense      blue/gray      +      ignition switch, black 7 pin plug, pin 5
Power Lock      blue/green (test with pass sw on models w/memory)      -      SJB, gray 26 pin plug (C), pin 17
Power Unlock      yellow/purple (test with pass sw on models w/mem)      -      SJB, gray 26 pin plug (C), pin 4
Lock Motor      PURPLE / green      5 wire      SJB, black 32 pin plug (D), pin 6
Unlock Motor      blue/green (models without memory)      5 wire      SJB, black 32 pin plug (D), pin 28
On models with memory, it is blue/green (5 wire) at the Driver Door Module, black 24 pin plug, pin 10.
Parking Lights+      PURPLE / white      +      SJB, gray 13 pin plug (E), pin 6
Parking Lights-      gray      -      headlight switch or SJB, black 52 pin plug (B), pin 31
May need to interrupt the headlight switch ground wire when triggering this wire. It is BLACK/ purple at the headlight switch, gray 10 pin plug, pin 3. See Tech Doc 1096 for wiring information.
Hazards      BROWN / yellow      -      hazard switch or SJB, black 52 pin plug (B), pin 48
Turn Signal(L)      blue/green (F); gray/orange (R)      +      SJB, black 26 pin plug (F), pin 21; gray 26 pin plug (C), pin 21
Turn Signal(R)      yellow/purple (F); GREEN/ orange (R)      +      SJB, black 26 pin plug (F), pin 23; gray 26 pin plug (C), pin 19
Reverse Light      GREEN/ brown      +      driver kick, harness to rear
Door Trigger      GREEN/ purple      - N.C.      SJB, gray 26 pin plug (C), pin 14
Dome Supervision      gray/purple (dome lamp); purple (puddle lamp)      +      SJB, gray 14 pin plug (A), pin 9; gray 26 pin plug (C), pin 12
Trunk/Hatch Pin      gray/orange      - N.C.      SJB, gray 26 pin plug (C), pin 16
Hood Pin      blue/orange      - N.C.      hood switch or SJB, black 26 pin plug (F), pin 10
Trunk/Hatch Release      BROWN / yellow      -      release switch or SJB, gray 26 pin plug (C), pin 20
Power Sliding Door      N/A
Factory Alarm Arm      arms on lock with door open
Factory Alarm Disarm      see disarm no unlock
Disarm No Unlock      Transponder and ignition
Tachometer      grn/blu, gry/yel, pur/gry, yel/org, brn, or grn/wh      ac      any fuel injector, gray or black 2 pin plug, pin 1
Wait to start      N/A
Brake Wire      PURPLE / white or YELLOW /GREEN      +      brake switch or SJB, black 52 pin plug (B), pin 40
Parking Brake      WHITE/ purple      -      parking brake switch or SJB, gray 26 pin plug (C), pin 1
Horn Trigger      blue/white      -      horn switch or SJB, black 52 pin plug (B), pin 41
Memory Seat 1      PURPLE / white      -      memory seat switch, black 8 pin plug, pin 2 or 7
Memory Seat 2      yellow      -      memory seat switch, black 8 pin plug, pin 6 or 3
Memory Seat 3      N/A      -
mikey_3776
Member - Posts: 7
Posted: May 13, 2014 at 10:09 PM / IP Logged
2011 Ford Taurus Non Intelligent Entry
I have searched and can't find the answer to this anywhere. I might be searching using the wrong terms but when reading this diagram, door trigger GREEN/ purple SBJ (smart juntion box) 26 pin plug pin 14 (I just used that as an example)
How do you identify what plug is the correct one? I'm not seeing any thing on the plugs themselves. There are a lot of green / purple wires. How do I narrow down which cluster to look in?
I can't find the door trigger wire anywhere but honestly I'm not sure where to look other than the SJB which has a bunch of connectors?
Thanks! ! !
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
