fortin evo all
monti755
Member - Posts: 21
Posted: March 26, 2014 at 8:11 AM / IP Logged
Why does the Tachometer Signal Die after you switch you A/T from Parking to R or D. What can cause this signal to die.
Platinum - Posts: 7,785
Posted: March 26, 2014 at 8:23 AM / IP Logged
Never even thought about it.  I always use the EVO-ALL's Tach signal output for remote starting only.  The vehicle is no longer under remote starter control after you step on the Brake Pedal to move the transmission shifter out of Park, so the remote starter doesn't need the Tach Signal any more.
howie (aka: harryharris)
Silver - Posts: 355
Posted: March 26, 2014 at 9:29 AM / IP Logged
The EVO-ALL isn't listed for the vehicle you previously mentioned, thus the software may be corrupted. Hardwire the tach from pin 9 on your OBD ll socket. Though I suspect some other cause for the engine to die.
As I mentioned in an earlier thread this Toyota is far simpler and more reliable hardwired.
Test before boxing up.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
