Prestige Remote Programing - FYI
stormusa
Posted: May 28, 2014 at 3:43 PM / IP Logged
To Program the 620TXP Transmitter:
With the system unlocked or disarmed, turn the ignition key to the on position.
Press and release the Program/Override push-button switch three times. The unit will flash the parking lights and/or beep the horn once to indicate that the system is in the transmitter program mode. The LED will also flash one time pause, one time pause, etc... indicating that you are in the transmitter program mode of the unit’s channel 1 or single button program mode.
Press and hold the lock button of each transmitter you wish to operate your system.
Once the transmitter has been programmed, turn the ignition switch off to exit the program mode.
The system allows priority button programming in case you intend to operate two vehicles with one transmitter. In this instance you will program the default button combination, (One Button Programming), for the main vehicle you drive, and a different combination for the second vehicle so you are not unlocking, locking, or starting both vehicles when they are within range of each other.
To prioritize transmitters after programming the transmitter into the first vehicle:
Enter the transmitter program of the second vehicle as above by:
Press and release the push-button switch three times. The unit will flash the parking lights and or beep the horn once to indicate that the system is in the transmitter program mode. The LED will also flash one time pause, one time pause, etc... indicating that you are in the transmitter program mode of the unit’s channel 1 or single button program mode.
Press and hold any combination of buttons of your transmitter that was not used for your primary vehicle. If, for instance you can press & hold the lock & unlock buttons simultaneously, for controlling Lock function of the second vehicle.
Press and release the program push-button switch once to advance to channel 2, unlock. Here you can press and hold the lock & start buttons simultaneously, for controlling the unlock function of the second vehicle.
Press and release the program push-button switch once to advance to channel 3, start. Here you can press and hold the start & option buttons simultaneously, for controlling the start function of the second vehicle.
Ace
Thursday, May 30, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
