where to pickup pulse
peterw102
Posted: August 22, 2014 at 2:06 PM / IP Logged
Greetings All. I am new to this Forum.
Have a 2014 Toyota Hilux pickup.
The 2 outside mirrors have to be retracted (folded) using a switch on the dash. I want to automate the retraction of these mirrors, as people keep bumping into my large mirrors at the malls.
Solution : I would like to use the remote fob to activate the auto-fold of the mirrors when I am out of the vehicle and lock it with the remote fob.
My question -
Where would be the best to pickup a pulse (pos. or neg.) to use as trigger mechanism to drive my custom relay circuit to auto-fold the mirrors ?
Was thinking to use pulse from the auto door lock circuit, but perhaps another pickup point would be easier ?
Here is the wiring diagram of the auto door lock.
Peter
peterw102
Posted: August 22, 2014 at 2:09 PM / IP Logged
where to pickup pulse -- posted image.
Posted: August 22, 2014 at 5:41 PM / IP Logged
Door lock motor wire for a POS pulse.
I think you have problems if you think Florida is in the UK, should know, I live at both of those addresses.
KPierson
Platinum - Posts: 3,527
Posted: August 24, 2014 at 7:56 PM / IP Logged
Use the (+) door lock pulse and set up the circuit to trigger from two pulses AND a lack of ignition voltage. This will allow you to only retract them when you want and will avoid any accidental activations while the car is on.
Kevin Pierson
Posted: August 25, 2014 at 12:14 AM / IP Logged
Wire the 85 side coil NEG of your "custom relay circuit" to ignition.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
