2013 Focus Se Hatchback Remote Starter
doboulepick
Posted: September 12, 2014 at 9:27 AM / IP Logged
Good day all,
i'm thinking of buying a remote Starter for my Ford (thinking of Compustart 2-WAY G9) to install it myself. but before doing that i would like to find the wiring diagram to make sure i do not get stuck in the process. Could anyone help providing the diagrams or better yet the pictorial to do so.
Thank you in advance for all your help
tonanzith
Gold - Posts: 593
Posted: September 12, 2014 at 2:30 PM / IP Logged
2013 (through 2016) focus all models except smart key
12 Volts     yellow (50A); red (50A)     +     BCM behind glove box, green 2 pin plug (G), pins 1, 2
Second 12 Volts     PURPLE / red (5A)     +     ignition switch, black 7 pin plug, pin 4
Starter     blue/white     +     ignition switch, black 7 pin plug, pin 7
Second Starter     N/A
Ignition     BROWN / yellow     +     ignition switch, black 7 pin plug, pin 1
Second Ignition     N/A
Third Ignition     N/A
Accessory     PURPLE / green     +     ignition switch, black 7 pin plug, pin 6
Second Accessory     N/A
Third Accessory     N/A
Keysense     blue/gray     +     ignition switch, black 7 pin plug, pin 5
Data Bus     yellow/orange (TX); PURPLE / gray (RX)     data     PATS Transceiver on ignition switch, black 4 pin plug, pins 3, 4
Can Bus High     gray/orange (MS CAN); WHITE/ blue (HS CAN)     data     data link connector, white 16 pin plug, pins 3, 6
Can Bus Low     PURPLE / orange (MS CAN); white (HS CAN)     data     data link connector, white 16 pin plug, pins 11, 14
Can Bus Sw     N/A
Power Lock     GREEN/ purple (with one-touch down only power wndw)     opn (typF)     BCM behind glove box, brown 60 pin plug (B), pin 55
On models with one-touch up/down power windows, it is black (open lock, - unlock (type F)) at the Driver Door Module, black 22 pin plug, pin 19. See Tech Doc 1099 for wiring information.
Power Unlock     (same as power lock)     - (type F)
Lock Motor     gray/brown (with one-touch down only power wndw)     5 wire     BCM behind glove box, brown 20 pin plug (E), pin 1
On models with one-touch up/down power windows, it is black at the Driver Door Module, black 22 pin plug, pin 3.
Driver Unlock Motor     WHITE/ orange (with one-touch down only power wndw)     5 wire     BCM behind glove box, brown 20 pin plug (E), pin 10
On models with one-touch up/down power windows, it is black at the Driver Door Module, black 22 pin plug, pin 4.
Passenger Unlock Motor     WHITE/ orange (with one-touch down only power wndw)     5 wire     BCM behind glove box, brown 20 pin plug (E), pin 8
On models with one-touch up/down power windows, it is black at the Passenger Door Module, gray 22 pin plug, pin 4.
Parking Lights (-)     (LIN bus)
Parking Lights (+)     yellow/blue (L); BROWN / yellow (R)     +     BCM behind glove box, green 42 pin plug (A), pins 1, 26
Hazards     BROWN / yellow     -     BCM behind glove box, blue 60 pin plug (C), pin 27
Turn Signal (Left)     blue/green (F); gray/orange or GREEN/ orange (R)     +     BCM, green 20 pin plug (D), pin 12; brown 60 pin plug (B), pin 6
Turn Signal (Right)     yellow/purple (F); GREEN/ orange (R)     +     BCM, green 42 pin plug (A), pin 22; brown 60 pin plug (B), pin 10
Headlight     BROWN / blue (L); blue/green (R)     +     BCM behind glove box, green 20 pin plug (D), pins 2, 1
AutoLights     (LIN bus)
Reverse Light     GREEN/ brown     +     BCM behind glove box, brown 20 pin plug (E), pin 19
Left Front Door Trigger     GREEN/ purple     - N.C.     driver kick or BCM behind glove box, brown 60 pin plug (B), pin 45
Right Front Door Trigger     white     - N.C.     BCM behind glove box, brown 60 pin plg (B), pin 46
Left Rear Door Trigger     green     - N.C.     BCM behind glove box, brown 60 pin plg (B), pin 44
Right Rear Door Trigger     yellow     - N.C.     BCM behind glove box, brown 60 pin plg (B), pin 25
Dome Supervision     WHITE/ brown     -     BCM behind glove box, gray 20 pin plug (H), pin 11
Trunk/Hatch Pin     yellow/orange     - N.C.     BCM behind glove box, brown 60 pin plug (B), pin 47
Rear Glass Pin     N/A
Hood Pin     blue/orange     - N.C.     BCM behind glove box, green 42 pin plug (A), pin 15
Trunk/Hatch Release     brown (rear handle switch)     -     BCM behind glove box, brown 60 pin plug (B), pin 49
Trunk Release Motor     yellow/purple     +     BCM behind glove box, brown 20 pin plug (E), pin 12
Fuel Door Release     N/A
Power Sliding Door (Left)     N/A
Power Sliding Door (Right)     N/A
Factory Alarm Arm     (arms on lock with door open)
Factory Alarm Disarm     (see disarm no unlock)
Disarm No Unlock     (transponder and ignition)
Trunk Alarm Shunt     N/A
Tachometer     GREEN/ blue, gray/yel, PURPLE / gray, or yellow/org     ac     frt of engine, bk 12P plg, pin 9,10, 11, 12, or 16P plg, pin 1, 4, 5, 6
Wait to Start     N/A
Neutral Safety     N/A
Clutch Pedal     blue/orange     -     BCM behind glove box, green 42 pin plg (A), pin 12
Also need to trigger GREEN/ purple (-) at the clutch switch, black 4 pin plug, pin 2.
Fuel Pump     yellow/blue     +     BCM behind glove box, brown 20 pin plug (E), pin 9
Rear Defroster     GREEN/ orange or blue/gray     -     BCM behind glove box, blue 60 pin plug (C), pin 45
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     brown     + 5K ohms     driver seat heater switch, black 6 pin plug, pin 5
Right Front Heated Seat     brown     + 5K ohms     passenger seat heater switch, gray 6 pin plug, pin 5
Speed Sense     (wheel speed sensor)
Brake Wire     GREEN/ red     +     brake switch or BCM behind glove box, green 42 pin plug (A), pin 16
Parking Brake     WHITE/ purple     -     park brk sw or BCM behind glove box, blue 60 pin plug (C), pin 25
Horn Trigger     PURPLE / green     -     BCM behind glove box, green 42 pin plug (A), pin 31
Wipers     blue/green     -     wiper switch or BCM behind glove box, blue 60 pin plug (C), pin 47
Left Front Window (Up/Down)     bn/gn-wh/pu or bu/wh-pu/gn (w/one touch down only)     A     master window sw, gry 10 pin plg, pins 8-6, or gry 8 pin plg, pins 3-4
On models with one-touch up/down power windows, they are blue - green at the Driver Door Module, black 22 pin plug, pins 1 - 12.
Right Front Window (Up/Down)     WHITE/ purple - BROWN / green (without one-touch)     A     driver kick, harness to rear
On models with one-touch up/down power windows, they are white - gray / YELLOW at the Passenger Door Module, gray 22 pin plug, pins 1 - 12.
Left Rear Window (Up/Down)     blue/orange - yellow (without one-touch)     A     driver kick, harness to rear
On models with one-touch up/down power windows, they are gray/brown - PURPLE / orange at the Left Rear Door Module, black 22 pin plug, pins 12 - 1.
Right Rear Window (Up/Down)     gray/purple - BROWN / green (without one-touch)     A     driver kick, harness to rear
On models with one-touch up/down power windows, they are PURPLE / white - yellow/orange at the Right Rear Door Module, black 22 pin plug, pins 12 - 1.
Sun Roof (Open/Close)     yellow/orange - PURPLE / brown (funct w/ign on only)     -     overhead console switch, black 16 pin plug, pins 12 - 11
Sun Roof (Limit/Close)     N/A
Memory Seat 1     N/A
Memory Seat 2     N/A
Memory Seat 3     N/A
Radio 12V     BROWN / red     +     radio, black 24 pin plug, pin 1
Radio Ground     black     -     radio, black 24 pin plug, pin 13
Radio Ignition     (Infotainment CAN)
Radio Illumination     brown (without SYNC)     + dimmer     radio controls, 8 pin plug, pin 3
Factory Amp Turn-on     yellow/purple     +     radio, black 26 pin plug, pin 18
Power Antenna     yellow/orange     +     radio, black 24 pin plug, pin 2
Left Front Speaker (+/-)     white - WHITE/ brown     +,-     radio, black 24 pin plug, pins 22 - 10
On models with amplifiier, the speaker wires are white - WHITE/ brown (woofer); PURPLE / orange - yellow/orange (tweeter) at the amplifier in LF cargo floor, gray 16 pin plug, pins 2 - 10; 3 - 11.
Right Front Speaker (+/-)     WHITE/ purple - WHITE/ orange     +,-     radio, black 24 pin plug, pins 23 - 11
On models with amplifiier, the speaker wires are WHITE/ purple - WHITE/ orange (woofer); GREEN/ orange - gray/orange (tweeter) at the amplifier in LF cargo floor, gray 16 pin plug, pins 6 - 14; 7 - 15.
Left Rear Speaker (+/-)     WHITE/ green or BROWN / green - BROWN / yellow     +,-     radio, black 24 pin plug, pins 21 - 9
On models with amplifiier, the speaker wires are WHITE/ green - BROWN / yellow at the amplifier in LF cargo floor, gray 16 pin plug, pins 4 - 12.
Right Rear Speaker (+/-)     BROWN / white - BROWN / blue     +,-     radio, black 24 pin plug, pins 24 - 12
On models with amplifiier, the speaker wires are BROWN / white - BROWN / blue at the amplifier in LF cargo floor, gray 16 pin plug, pins 8 - 16.
Center Channel (+/-)     blue - PURPLE / green     +,-     radio, black 24 pin plug, pins 20 - 8
On models with amplifiier, the speaker wires are green - gray / YELLOW at the amplifier in LF cargo floor, gray 16 pin plug, pins 1 - 9.
Subwoofer (+/-)     purple - yellow (1); GREEN/ purple - gray (2)     +,-     amplifier in LF cargo floor, blue 16 pin plug, pins 1 - 9; 2 - 10
Aux. Audio Input Left (+/-)     blue/red - (shield) (without SYNC)     +,-     radio, black 24 pin plug, pins 17 - 6
Aux. Audio Input Right (+/-)     BROWN / red - (shield) (without SYNC)     +,-     radio, black 24 pin plug, pins 18 - 6
RSE Video (+/-)     blu-grn (rear view cam); brn-brn/yel (aux. video)     +,-     SYNC Mod/display, bk 54 pin plg, pins 14-15; 34-35
RSE Audio Left (+/-)     green - gray or blue - gray/orange (SYNC audio)     +,-     radio, black 26 pin plug, pins 12 - 25
RSE Audio Right (+/-)     purple - yellow or pur/grn - brn/wht (SYNC audio)     +,-     radio, black 26 pin plug, pins 13 - 26
Satellite Radio 12 Volts     (built into radio)
Satellite Radio Ground     N/A
Satellite Radio Ignition     N/A
Satellite Radio Antenna     N/A
Satellite Audio Left (+/-)     N/A
Satellite Audio Right (+/-)     N/A
Item     Size     Depth     Location
Headunit     irregular center of dash
Left Front Speaker     6 x 8     3.8     left front door
Left Front Tweeter   left front door
Right Front Speaker     6 x 8     3.8     right front door
Right Front Tweeter   right front door
Left Rear Speaker     6 x 8     4 - 5     left rear door
Left Rear Tweeter   left rear door
Right Rear Speaker     6 x 8     4 - 5     right rear door
Right Rear Tweeter   right rear door
Center Channel   top center of dash
Subwoofer   right side of cargo compartment
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner     (built into radio)
Gary Sather
doboulepick
Posted: September 12, 2014 at 3:03 PM / IP Logged
Thank you Gary for the quick info, onle last question what do you mean by smart Key.
thanks
Posted: September 12, 2014 at 4:33 PM / IP Logged
Key in ignition switch or push button start (= smart key).
doboulepick
Posted: September 13, 2014 at 7:30 AM / IP Logged
Thanks Howie I thought that's what it was but did not want to go on on an assumption and mess-up something. Thanks guys for the help
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
