compustar cm7200 reservation mode
tianot
Copper - Posts: 155
Posted: September 16, 2014 at 12:58 AM / IP Logged
hello guys! i need your help.
i installed a compustar cm7200 module into a 2002 mazda protege manual transmission. i did all the wirings from clutch to parking brake up to door trigger. when i set the car into reservation mode the car will not lock the door once you get out and  close the door. when i set the reservation mode the car still running when i take off the key and then open the door and close it. the car shut off once the door is close, but it won't lock and it will not activate the reservation mode. when i try to remote start the start im getting a error 7 which is reservation is off. do u guys have any idea whats wrong with it? do i need something to do with the door trigger? i use the BLACK/ blue door trigger wire from the harness to rear.
thanks
tianot
dman007
Copper - Posts: 106
Posted: September 16, 2014 at 8:15 PM / IP Logged
The fact that the car shuts down, once the door is closed. Proves that the door trigger is correct, I would look into the lock/unlock wires.
Do they function normally without attempting reservation mode?
DTS Performance
St Petersburg, FL
tianot
Copper - Posts: 155
Posted: September 16, 2014 at 8:59 PM / IP Logged
the lock and unlock are working good when the car is not in reservation mode. i use the light GREEN/ red wire. lock to 1.5k and unlock to ground.
i tried to use a another cm7200 module and it does the same thing. you think its something wrong with the transmitter?
how about the domelight delay settings? do i need to adjust that to auto?
tianot
supermike05
Posted: September 16, 2014 at 11:27 PM / IP Logged
have you made sure that the green loop is cut so that the cm7200 brian knows that the car is a manule transmision
supermike05
Posted: September 16, 2014 at 11:28 PM / IP Logged
tianot
Copper - Posts: 155
Posted: September 16, 2014 at 11:31 PM / IP Logged
the car is a manual transmission.
green loop cut is for automatic transmission.
tianot
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
